Playing with Desktop Dyno again.
It's snowing and cold out, and my truck is right out in the middle of it.
So what better way to waste time than on Desktop Dyno? I dont think I'll ever get tired of that program.
I came up with this idea. What do you think?
Bore X Stroke: 4.030" X 3.5" (352 block and 360 crank, rods)
Custom 15cc dome pistons, .010" deck clearance, .020" head gasket, 12.3:1 compression
Ported D2TE-AA heads, standard FE valves
600cfm carburetor, dual plane intake
Open headers
Fuel: Ethyl Alcohol or Methyl Alcohol
Custom solid lifter cam:
IVO: 29
IVC: 61
EVO: 75
EVC: 27
LSA: 110
Intake Centerline: 106
Intake lift: .540"
Exhaust lift: .571"
Intake duration: 270
Exhaust duration: 282
Five points to the first person to tell me where I got the idea for that cam.
So, Desktop Dyno 2000 says this thing would make 509hp @ 6000rpm, and 511ft-lbs @ 4000rpm, with Methanol, slightly less with Ethanol. Anyone with a different dyno program want to verify those numbers?
I'm sure it would be fun to build one of these, and I do have the 352 block and 3.5" stroke crank ready to go...
Open headers
IVO: 29
IVC: 61
EVO: 75
EVC: 27
LSA: 110
Intake lift: .540"
Exhaust lift: .571"
