launch date? - Page 3 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
launch date?
  #31
Old 12-17-2005, 09:39 AM
Casey Casey is offline
Casey is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Batu
Your built date is wrong. I believe they starting building the 6.0 late 2002 as a 2003 model.
I have a 2004 with a built date of 9/19/03, which is a good truck. Have had only a few problem to date with 32000 miles.
You're right! I mistyped. Change the 2003 to 2002 and my post will be correct.
After November 2002 Ford did not build the 7.3L in ANYTHING.
  #32
Old 12-17-2005, 10:38 AM
PSD6litre40's Avatar
PSD6litre40 PSD6litre40 is offline
PSD6litre40 is starting off with a positive reputation.
They still manufactur and produce vehicles in Australia with the 7.3 DIT in it....... and no the 04 F450's were 6.0's only....
  #33
Old 12-17-2005, 04:52 PM
NickFordMan's Avatar
NickFordMan NickFordMan is offline
NickFordMan is gaining momentum as a positive member of FTE.
Actually, Australia doesn't produce them, according to what Fred has said, they are being produced in Brazil.
  #34
Old 12-19-2005, 03:35 PM
Batgeek's Avatar
Batgeek Batgeek is offline
Batgeek is starting off with a positive reputation.
It really starts getting weird when you start looking at Ford's global website. They make the Ford F250 for Brazilian market with a 4.2L 6c turbo diesel "they also come with a LOJACK installed". In Australia they're offered with the 5.4 gasser or the 7.3L turbo diesel but made in Brazil. It's wierd how they launch a new truck here but continue to produce the old style somewhere else or vice versa.
  #35
Old 12-19-2005, 04:16 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
That Brazilian made truck is also sold in South Africa with the 4.2 MWM engine.
The 4.2 used to be sold here up until 2003 - but got dropped due to emissions. The BEST diesel I have ever worked with, would run for a million miles no dramas, a little underpowered though.
MWM recently got bought out by Navistar, and I believe the South American F-trucks are going to the 4BT Cummins...
  #36
Old 12-19-2005, 05:56 PM
Why would they use the 4BT Cummins? Its only got 125 HP and is a very small liter engine, 3.9L all it is a 5.9 ISB with 2 cylinders cut off........
  #37
Old 12-19-2005, 06:03 PM
They don't give a damm about power - thats why.
I do believe it will be the Common Rail variant with more than 125hp though...
  #38
Old 12-20-2005, 12:51 AM
polarbear's Avatar
polarbear polarbear is offline
polarbear is a splendid one to beholdpolarbear is a splendid one to beholdpolarbear is a splendid one to beholdpolarbear is a splendid one to beholdpolarbear is a splendid one to beholdpolarbear is a splendid one to beholdpolarbear is a splendid one to behold
Funny- you brought up a great point. This is the only country on the planet that puts power/performance as the top priority in a diesel. For most third-world countries, it's the ability to run on crappy fuel, in extreme climates, with a minimum of maintenance and repairs. In Europe, fuel mileage takes top slot. In Australia, power is an issue- but not for towing speed. Anyone that's ever seen a "road train" knows what I'm talking about- it's the ability to pull ungodly amounts of weight down mostly unpaved roads in extreme heat.
  #39
Old 12-20-2005, 01:06 AM
Quote:
This is the only country on the planet that puts power/performance as the top priority in an engine.
Just thought I would change that
I am still amazed at the people that call a 300hp 5.4l V8 "underpowered"...
Here we still get the 260hp 2V version, and in the trade world (read: owners that haul 3 tons) it is considered an absolute belter in terms of performance.
- the reason being they are used to a 90hp diesel to do the same thing.
I don't think any of us (me included) are in a posistion to complain about performance.
Until you have seen a Suzuki Van powered by a 600cc triple hauling over a ton going up an 8% grade in SE Asia you don't quite understand what the rest of the world has to live with in terms of performance.
Having said that, more power is always good
  #40
Old 12-20-2005, 01:31 AM
polarbear's Avatar
If there wasn't a 345 HP Silverado in the 'hood with better transmission gearing, it probably wouldn't be. Hint- check the 1st gear ratio on the GM tranny and the Ford tranny- explains everything. edit: except the drive-by-wire thing. The F150/Expy is geared sluggish off the line, and has the DBW to further delay forward progress.
Once upon a time, a typical US 3/4T pickup had a 300 six and a 4-spd transmission. Folks put Campers on them, hung boats out the back, and the trucks went everywhere- and back. Not at 70 mph uphill, mind you- but they got there, first time/every time.
  #41
Old 01-08-2006, 05:13 PM
Astrovan Man Astrovan Man is offline
Astrovan Man is starting off with a positive reputation.
The new mid year 2006 GMC/Chevy Pick up offer an automatic SIX SPEED ALLISON Transmission. Any word on the 2007 F250/F350 to do the same to the Torque Shift ? Or is that overkill to mess with the Toqueshift five speed ?
How many RPM's is too high to launch at? robs01f250 1999 - 2003 7.3L Power Stroke Diesel 22 01-29-2009 08:08 AM
best gear ratio for a good hard launch? awfulaggravated Clutch, Transmission, Differential, Axle & Transfer Case 4 12-04-2008 08:45 AM
LSD Rear End true4.2 3.8 & 4.2L V6 20 03-16-2004 10:12 AM
Remember the '89 Ranger I was going to get? TONS of newbie questions inside! W.O.T. Stang Ranger & B-Series 5 10-26-2003 10:35 PM
1999 Ford F150 Spark Plug #4 thomasmc Modular V8 (4.6L, 5.4L) 3 07-04-2003 11:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
