how do i check if my glow plugs are good? - Ford Truck Enthusiasts Forums
Old 11-29-2005, 08:32 AM
soobad soobad is offline
soobad is starting off with a positive reputation.
how do i check if my glow plugs are good? is there a test? getting colder now and my truck is not starting very well in the mornings, i crank it for 30 seconds then i have the cycle the glow plugs twice by turning the key off and on before starting,,,,,did that just make any sence?...LOL
Old 11-29-2005, 10:14 AM
Hamberger Hamberger is offline
Hamberger is starting off with a positive reputation.
Glowplugs
Pull of the electrical connectors and take a 12V Test light. Put the pigtail on the +ve on your battery and check each plug by touching the electrical connection of the plug with your test light. Make sure not to not touch the body of the plug as it is always grounded.
1.0 If the Test light lights up brighly the plug is good.
2.0 If the Test light does not light up the plug is bad, change it.
3.0 If the Test light is dim, the plug is pretty much gone, change it.
Every plug I every had to deal with was either 1.0 or 2.0 above, a dim light (poor resistance) is rare and I have never seen one yet. I was always
Old 11-29-2005, 08:10 PM
trike1946's Avatar
trike1946 trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
Always use motorcraft/beru plugs. Use anti seize and watch the torque. Be careful cranking too long. Your starter won't like it. Gets hot quick. Expensive. Make sure your batteries are good and all conections are clean.
Old 11-30-2005, 09:04 PM
_Gadget _Gadget is offline
_Gadget is starting off with a positive reputation.
May not just be plugs - it's possible that the glow plug controller is bad.
Old 11-30-2005, 09:49 PM
yeah i checked the glow plugs and they seam strong, how and where is this controller and how do you check it?
Old 11-30-2005, 11:57 PM
mhannink mhannink is offline
mhannink is new and has a neutral reputation at this point.
the rely is on the back of the intake its under a little plastic cover and it will look like the starter relay w/ a bunch of wires on it
Old 12-01-2005, 06:16 AM
trike1946's Avatar
Have you tried plugging it in at night? How old are the batteries? Do you have good connections?
Old 12-01-2005, 12:29 PM
smiller4597 smiller4597 is offline
smiller4597 is starting off with a positive reputation.
Old 12-01-2005, 12:30 PM
Brian460 Brian460 is offline
Brian460 is starting off with a positive reputation.
This is a good way to check them but also remember the test light will light brightly when a glow plug has shorted out also.
Old 12-01-2005, 12:37 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is online now
bigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant future
When your controler is operating properly you should hear it cycle on- off a couple of times when the wait to start light goes out. Right now - if it is 20 deg outside - then the controler should stay on around 15 seconds. In my 93 I've changed the controler 3 times in 12 years. Glow plugs once.
Troubleshooting glow plugs dev_jhnsn 1994.5 - 1997 7.3L Power Stroke Diesel 20 02-20-2015 08:23 AM
Glow plugs/glow plug light. bigcountry1009 1999 to 2016 Super Duty 3 08-29-2014 04:03 AM
Glow plug issues do the evolution 1999 - 2003 7.3L Power Stroke Diesel 2 11-17-2006 02:33 PM
1997 F350 Glow Plugs batesfarmer 1994.5 - 1997 7.3L Power Stroke Diesel 7 02-04-2006 08:36 PM
glow plug module powerglyde1234 1999 - 2003 7.3L Power Stroke Diesel 1 11-07-2005 11:31 PM
Tags
2001, 73, 99, change, check, checking, controller, diesel, f250, ford, glow, plug, plugs, powerstroke, psd, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
