Spark Plugs - Ford Truck Enthusiasts Forums
Spark Plugs
Old 11-28-2005, 09:57 PM
2kstroker 2kstroker is offline
2kstroker is starting off with a positive reputation.
Thumbs up Spark Plugs
It's time to change the plugs in my 1998 Explorer,4.0 SOHC. Ford suggests AGRF-22P. Is one type(platinum v/s double platinum v/s single point v/s dual point v/s etc,and brand (Autolite v/s Bosch v/s Champion v/s etc,etc,etc,better than another?
Some vehicles seem to run better on one type rather than another.
You all have always come through,with good responses.
Thanks again,for all your help.
Old 11-29-2005, 12:19 AM
Jharger Jharger is offline
Jharger is starting off with a positive reputation.
The single P will give you a platinum tab on the ground electrode and dual P's (PP) gives you platinum on the ground and center electrodes so the platinum faces each other. I use the PP's as they seem to last longer - except the one plug that somehow lost a platinum tab last year.
Brands are a funny topic. Some folks on this forum are adimate about certain brands. I never really noticed a difference. I've used Motorcraft,Champion once I think and right now have Autolites. I would stay away from those Bosch 4 pronged things. Does not make sense to my why those are better. Electricity takes a single path of least resistance. So only 1 ground electrode will ever get the spark for any given coil fire. The other 3 then are left there in the combustion chamber to provide more sharp edges to get hot and start pre-detonation/pinging. My 2 cents.
Old 11-29-2005, 11:35 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
I've always used the double platinum Motorcrafts since that's what's recommended. No problems. If this is the first time you are changing them, best way to get to the plugs in through the wheel wells. You also might consider changing the wires while you are in there.
Old 11-29-2005, 10:52 PM
Viking2005's Avatar
Viking2005 Viking2005 is offline
Viking2005 is starting off with a positive reputation.
As marragtop stated, I would recommend staying with the Motorcraft plugs. I made it to over 140,000 miles on my 97 Explorer XLT SOHC 4.0L, that was one spark plug change every 30,000 miles. I never had problems wit the stock Motorcraft plugs. In my previous 93 Explorer I tried Bosch, no benefit, just costs more than Motorcraft. I have had problems with Autolite and Champion in past, I even had a Autolite plug come apart on me, insulator seperating from plug body.
Old 11-30-2005, 08:18 AM
pilot815 pilot815 is offline
pilot815 is starting off with a positive reputation.
I just took off my plat +4's and put autolite PP. mileage is WAY WAY up, even though i can tell there is less power than before. Id rather have the mileage over power though.
Old 11-30-2005, 11:18 AM
I can understand how mileage can be accounted for. How do you measure the power difference?
Old 11-30-2005, 06:00 PM
Just the feel of acceleration, it doesnt seem to accelerate as fast. That, and i raced it against a stock sport trac at a drag strip. I ran at 85mph, and he ran at 65mph at best. But i also have an intake so it wasnt purely the plugs.
Old 05-30-2014, 09:43 PM
Sketer Sketer is offline
Sketer is starting off with a positive reputation.
I have AGRF-22P spark plugs that will need changed soon in my 1997 Ranger w/4.0L .
The problem is that number plug has been dropped. What plug number would replace it ?
Thanks -
Old 06-02-2014, 05:02 PM
Liquid_force Liquid_force is offline
Liquid_force is starting off with a positive reputation.
Looks like SP-500 if you want original equivalent Motorcraft.
I've used Autolite "OE style" in all my ford cars/trucks for the past ~15 yrs covering about 300k miles. Those have been turbo 2.3L, n/a 2.0L, 3.4L v8 and 4.6L DOHC.
2006 5.4 Spark Plug Change- 100% success & procedure I used Beechkid 2004 - 2008 F150 40 06-22-2016 10:26 PM
Glow plugs hotrodfeguy 1999 - 2003 7.3L Power Stroke Diesel 7 10-10-2014 12:20 PM
Bosch Platinum +4 Spark Plugs-Any Good? DictatorDanny General Automotive Discussion 20 02-09-2005 11:20 PM
Debunking the Myths of Bosch Platinum Plugs Rockledge 3.0L V6 4 08-24-2003 11:40 PM
Best EFI 460 ignition? Skeetkiller Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 03-02-2003 11:57 PM
Tags
2000, agrf22p, agrf22pg, bosch, champion, change, explorer, location, motorcraft, plug, plugs, problems, spark, sport, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
