Fuel Return Tee Diagram,help
I Have An 85 F250 6.9.i Need A Diagram Please On How The Fuel Return Tee's Are Supposed To Be Plumbed.the Previous Owner Has Tee's Coming Off The Plastic Tee's In 2 Spots.the Chilton And Haynes Manual Don't Show Either One Of Them.the Return Tee Kit Only Has 1 Cap That Has Only 1 Nipple On It.the Old Owner Has It Looping From #1 Cyl. To #2 Cyl.also,where Should The Line From The Fuel Filter(not The Hard Line) Go.a Top View Of How It Is Supposed To Be Hooked Up Would Be Greatly Appreciated.thank You Much.
Also don't forget ther return line from the IP should have a couple of tees in it so the injector lines get tied to it.
Drivers side: 2 - 4 - 6 - 8 - Return line from IP
Passenger side: fuel filter return - 1 - 3 - 5 - 7 - return line from IP
Return line from IP picks up the injector return line at the back of the intake manifold then goes to fuel tank selector valve.
The replacement kits are not the same as OEM. They have too many nipples. I ran mine in a circle and bypassed the fuel filter all together. my ip return line runs down the intake manifold to the rear of the driver side head from there it t's to the return lines from the injectors to the fuel tank return. As far as the fuel filter nipple goes, I used a short piece of fuel line and a new clean stainless bolt to plug it with.
LARIAT 85
20
07-29-2017 07:06 AM
lazzarruss
11-20-2013 09:12 PM
