Diesel in antifreeze
Originally Posted by cookie88
Hey Ryan, any idea where we can get the remove/install tools for the cups? I've checked the Snap-on catalog, the Rotunda catalog, and two Ford dealers with no luck.
jimbo
yes that is the other kind of leak. i got the diagnosis for that also if you want it. but i am pretty sure he said it was diesel.
i also forgot to mention. i hear a lot about a place that sells tools called "OTC" over at the tds. it sounds like a specialty tool place. they may have it. i dont know who or where they are but i am sure they have a web site.
thats the common place for oil to get into the water is the oil cooler since its a heat exchanger, either the internals pinhole or the orings fail. i had it happen on my 94.5 and it was just the orings. it was like $50 for the kit to rebuild it.
the oil was showing up in the degauze bottle making a grey goo on the top of the water.
is he sure its diesel?? old oil sure does have that sweet diesel smell to it.
What about the oil cooler? Been reading some in the IDI forum and apperaently on those engines a bad oil cooler can allow oil into the coolant. On the PSD the block heater does pass right through the oil cooler head.....any way for coolant to get into the oil there?
is he sure its diesel?? YES old oil sure does have that sweet diesel smell to it.
I drained and flushed the cooling system. Refilled it with only water. Drove about ten miles until the engine was warm. Got diesel in the coolant.
http://www.lpcinc.us/rotunda-4.htm
try these guys. they had one but sold it. see if they got another. its the 3rd item from the top.
found some more stuff
http://www.otctools.com/frames-newcatalog.php3
i am sure some of this stuff will work. who knows. in my searches i read somewhere otc makes rotunda tools so maybe a call to them will turn up what you need.
#29
I'm going to the dentist in the morning and getting it over with!!!
