4.0L with 5spd Tranny
Old 11-28-2005, 07:56 AM
penman39's Avatar
penman39
penman39 is offline
Hi,
My son fried his tranny because it had a slow leak and he ignored me every time I told him to check the fluid level. It siezed up on him. How many different trannys were used in the 93 Ranger 4X4's and how can I tell which one he has? Any good sources for a replacement unit that won't cost an arm and a leg?
Thanks
Old 11-28-2005, 09:59 AM
frankenbroncoII's Avatar
frankenbroncoII
frankenbroncoII is offline
more than likely he has the M5OD. these are the easiest to id because the transmission and bell housing are one peice, and it doesnt have a pan/cover on the bottom of the transmission it self.
Old 11-29-2005, 09:45 AM
01TwoFitty's Avatar
01TwoFitty
01TwoFitty is offline
Old 11-29-2005, 07:55 PM
RangerPilot's Avatar
RangerPilot
RangerPilot is offline
The M5OD is a very common tranny, it's the standard 5 speed manual tranny on the Rangers.
You'll need the R-1 version, not the R-2 version, which is a little more heavy duty for the F-150.
It's not exactly strong. Before putting it into your vehicle, make sure to remove the three rubber shift rail plugs at the top of the tranny and replace them with brass or comparable ones, they degrade and leak and probably friend your sons tranny.
Best of luck, keep us informed.
Woot, 1000 posts!!!
Old 11-30-2005, 04:21 AM
ColonyPark's Avatar
ColonyPark
ColonyPark is offline
Out of curiosity, why can't the R-2 be used in place of the R-1? I was under the impression that they're basically the same tranny, both M50D's. I was hoping that I could use the stouter transmission if (when) I need to replace my M5ODR1.
I talked to a guy in CA not long ago who replaced his 3.0 Ranger M5ODR1 HD with an M5ODR2. The only problem they had was the need to also replace the starter because the old one didn't mount the same as the R2 starter. Instead of replacing the starter, they swapped the innards of the R2 into the R1 case. I guess the labor was free...
CJB
Old 11-30-2005, 09:12 PM
el conquistador's Avatar
el conquistador
el conquistador is offline
i'd imagine the gearing is different for R2 trans. since its used in the f150.
Old 11-30-2005, 09:17 PM
natebaker's Avatar
natebaker
natebaker is offline
My guess would be stronger bearings. Maybe hardened gears for a little bit more durability under more stress.
Old 11-30-2005, 10:18 PM
ColonyPark's Avatar
ColonyPark
Hadn't thought about the possibility of different ratios until you mentioned it, so I thought I'd look it up. Here's the breakdown according to http://www.hardcore50.com/technical_articles/GearRatios.htm
M5ODR1 with a 2.3 or 3.0:
1st 3.72, 2nd 2.20, 3rd 1.50, 4th 1.00, 5th 0.79
M5ODR1 and M5ODR1 HD with a 4.0
1st 3.40, 2nd 2.05, 3rd 1.31, 4th 1.00, 5th 0.79
M5ODR2
1st 3.91, 2nd 2.24, 3rd 1.49, 4th 1.00, 5th 0.80
So, it would appear that the gearing of the M5ODR2 is actually closer to the M5ODR1 used in the 2.3 and 3.0 than the M5ODR1 or R1HD used for the 4.0. The big difference is in 1st gear. Seems to me that the ratio of the R2 would be really nice on the 2.3.
Lastly, a person with a 2.3 or 3.0 would be better off, ratio wise, with an R2 out of an F150 than an R1HD out of a 4.0.
Having said all that, does anyone know of a reason that the R2 won't bolt up to a 2.3 or either V-6 in the Ranger? Obviously the R2 is built to last longer. I'd rather have an overbuilt transmission than an underbuilt one.
Old 11-30-2005, 10:33 PM
natebaker's Avatar
natebaker
Now that is just queer. Maybe the M5ODR1 HD was just made to fit the 4.0s power range better. Idk...
Old 11-30-2005, 10:51 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
CowboyBilly9Mile is offline
Anyone else wonder if maybe the bolt pattern on the bellhousing of a 4.0 is different than a 4.2?
Old 11-30-2005, 10:57 PM
AlfredB1979's Avatar
AlfredB1979
AlfredB1979 is offline
The 4.0L is a 60* bell pattern and the 4.2L is a Windsor SBF 90* pattern.
If the Ranger version of that tranny is an indication, the bells don't swap.
From reading that mag at Wal-Mart (a Ford truck mag), there was a tech article about "freshening" a Ford F150 stickshifter tranny...evidently, they are not "all that" in terms of strength, either.
Old 12-01-2005, 12:51 PM
ColonyPark's Avatar
ColonyPark
So the real lessons learned are:
1. Don't mate a R1HD to a 2.3 unless you want to lug the engine all the time.
2. If you want an R2, you gotta swap the innards of one into your R1 case.
I'm assuming the bell housings are molded as part of the tranny case and not swappable, right?
Old 12-01-2005, 02:57 PM
RangerPilot
One peice, bell housing is a part of the case. Not swappable.
Stick with the tranny that came with the vehicle, it's designed for the vehicle for that reason. The R2 isn't all that great, but would be much nicer than the R1 in terms of strength. Then again, if you're hurting that tranny you're obviously overworking your Ranger.
Old 12-01-2005, 03:09 PM
CowboyBilly9Mile
Yup, that's just what I suspected.
stagegrunt
1999 to 2016 Super Duty
05-21-2010 03:05 PM
mrad
11-08-2009 10:00 PM
Peter94
06-13-2007 10:01 PM
CVTom
10-21-2005 06:21 PM
Quick Reply: 4.0L with 5spd Tranny
