what should they fix - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Closed Thread
Old 11-27-2005, 01:11 PM
ford4.9's Avatar
ford4.9 ford4.9 is offline
ford4.9 is starting off with a positive reputation.
Question what should they fix
Clearly there was problems with the 6.0. From what I have read most of them where with the turbo, the sensors, egrs, head gaskets (maybe because of the previous three), and oil leaks. For the most part, the bottom end seems to be good. Sense there replacing the turbo with turbos maybe that will fix the turbo problem, but what about the rest? what would you all like to see ford do? More head studs? More sensors? better sensors? no sensors? egrs? oil leaks?
Old 11-27-2005, 02:43 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
i would personally like to see head studs and o-ringed heads. the boost pressure on this engine from the factory will most likely be above 35psi. it is just hard to make that much power with this relatively small displacement (compared to OTR engines) without that much boost. not to mention the wave of performance mods that will come out soon after release that will make alot more boost. i would also like to see new and improved split-shot injectors. Less EGR's will be nice too, but it isnt going to happen. good thing they have a plug on them. the bottom ends on these things are immaculate, to say the least.
what i would like most of all, is better reliability. the only thing that is wrong with our 6.0 is reliabilty. if they could get the reliabilty close to the late-model 7.3's, then this will be an awesome engine, that will spank the 7.3 power-wise, and if it has that kind of reliability, it will be even better. sure it is going to have teething problems, which time will only fix. the legendary 7.3 even had its fair share of teething problems. if ford did enough of their homework, then this engine should be very reliable, based on the number of years in development. if the 6.0 would have stayed out longer, it too would become reliable. i think that 2003 and 2004 model engines were the R&D of the engine, and the model years 2005 and 2006, ford started to a higher percentage of these right.
one thing i DO NOT want to see, is a quiet engine, such as the Durasmack. that thing is just too quiet, one reason why i hate it. this engine will most likely have the same top-end rumble that the VT365 has, and that is awesome.
Old 11-27-2005, 03:51 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
That would be my vote, they seem to, on many occasions have gotten most if not all bugs worked out of the electronics and injectors.
Of course that is only my opinion
Old 11-27-2005, 04:01 PM
ford4.9's Avatar
Do you think a good part of the problems with head gaskets where cause by the failure of egr's and injectors leaking fluid into combustion?
Old 11-27-2005, 10:03 PM
hardly. modified trucks were running wayy too much pressure to safely run stock bolts, and over time, it stretched the bolts. eventually the cylinders pressed the heads up off of the surface of the gasket, and at the right time, it will blow out a gasket.
Old 11-27-2005, 11:22 PM
Customz's Avatar
Customz Customz is offline
Customz has a good reputation on FTE.Customz has a good reputation on FTE.Customz has a good reputation on FTE.
I haven't heard of any turbo problems and I think ford has fixed everything.
I believe they should keep an eye on the head gaskets and egr...nature of the beast.
Old 11-27-2005, 11:58 PM
Jerme Jerme is offline
Jerme is starting off with a positive reputation.
I think the turbo problems were just the variable vanes sticking, but twins will definently take care of that.
Old 11-28-2005, 10:49 AM
kw5413's Avatar
kw5413 kw5413 is offline
kw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputation
Well, as much as I absolutely despise the EGR Valve strategy...I know, you are all shocked about that little revelation...If Ford goes with the bigger dual EGR Valves and Coolers, we should see some relief.
With that said however, I fear this strategy will only delay the inevitable. We will still see EGR Valves sticking just not as quickly.
Coolant loss...no matter the reason...needs to go away.
I wonder how many sensors they will add?
Old 11-28-2005, 12:40 PM
ford4.9's Avatar
I don't see a decrease in sensors. I just hope that they test them and not buy from the cheapest company out there.
Old 11-28-2005, 12:43 PM
ford4.9's Avatar
What I don't get about the 6.0 is the oil leaks? Why has this not been address?? It seems that all years have it.
Old 11-28-2005, 02:23 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
Former Vendor
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
Quote:
No kidding I think sensor reliability is where MOST of the 6.0's problem lies...Ford really dropped the ball on that one.
Old 11-30-2005, 12:22 AM
mhannink mhannink is offline
mhannink is new and has a neutral reputation at this point.
or the should just dump the whole psd program and go w/ a cat or other heavy duty engine(to bad dodge is keeping cummins)
Old 11-30-2005, 01:13 AM
NickFordMan's Avatar
NickFordMan NickFordMan is offline
NickFordMan is gaining momentum as a positive member of FTE.
Let's not start that up...
Old 11-30-2005, 09:08 PM
Quote:
why not i think a cat tho low rpm would be a great motor finally be able to compte w/ the dodges
Old 12-01-2005, 01:52 AM
...and so it starts...
I was reffering to the Cummins comment...if you want one so bad, just go buy a Dodge. The Powerstroke has been dominating performance the last time I checked. The 6.0L is making less torque right now, and is slightly slower of the line due to this (and I mean slightly)...but manages to man-handle the competitors like nothing. Don't give me this Cummins crap.
Closed Thread
Troubleshooting a "low power" condition bismic 6.0L Power Stroke Diesel 10 09-23-2014 08:17 PM
What's up with this? Str8shooter 6.7L Power Stroke Diesel 0 06-29-2013 01:54 AM
Howling turbo? 99F350bigorange 1999 - 2003 7.3L Power Stroke Diesel 27 02-08-2013 06:10 PM
Turbo Cleaning? Maybe Not! hifiman 6.0L Power Stroke Diesel 11 09-12-2010 10:28 AM
Advice Needed (Turbo Endplay) tidbit 6.0L Power Stroke Diesel 5 08-10-2009 11:22 AM
Tags
1997, 60l, bolts, boost, dieselpowermagcomtechevery, dt444, engine, head, international, pressure, problem, problems, solved, specs, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
