Best Way to Seafoam a 2.3 Lima?
Old 11-26-2005, 09:29 PM
ColonyPark's Avatar
ColonyPark
ColonyPark is offline
What vacuum hose should I use to "Seafoam" my 2.3? What's the proceedure exactly?
Thanks!
Old 12-04-2005, 11:33 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
Exact procedure, I don't know...but I've read about using the power brake hose for its large size (if you have power brakes...if not, use the largest manifold hose you have.)
I would think you'll have to get the RPMs up a bit especially since it'll want to stall at idle with that huge vacuum leak you've created by taking the hose off. Trickle the Seafoam stuff into the hose in small doses, allowing it time to burn the stuff out and recover smooth running between doses. Hook everything back up and drive off.
Old 02-18-2006, 06:37 PM
crazypaw's Avatar
crazypaw
crazypaw is offline
Hi TigerDan,
Seafoam is not introduced into the injection / injectors it's just for the intake manifold; to hopefully eliminate carbon build-up?
MKLC
19
12-14-2021 11:40 AM
Mat523
Modular V8 (4.6L, 5.4L)
19
07-15-2015 07:00 PM
cchsbuzz19
Modular V10 (6.8l)
08-14-2014 10:54 PM
booblinker
05-18-2014 10:01 AM
Garrett248
05-08-2014 09:29 PM
Quick Reply: Best Way to Seafoam a 2.3 Lima?
