Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-26-2005, 09:29 PM
ColonyPark ColonyPark is offline
Garage is empty, add now
ColonyPark is starting off with a positive reputation.
Best Way to Seafoam a 2.3 Lima?
What vacuum hose should I use to "Seafoam" my 2.3? What's the proceedure exactly?
Thanks!
__________________
1997 Ranger XLT SuperCab 2.3 5 Speed
1998 Explorer Eddie Bauer 4.0 OHC
2003 E-150 Club Wagon 5.4
  #2 (permalink)
Old 12-04-2005, 11:33 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Exact procedure, I don't know...but I've read about using the power brake hose for its large size (if you have power brakes...if not, use the largest manifold hose you have.)
I would think you'll have to get the RPMs up a bit especially since it'll want to stall at idle with that huge vacuum leak you've created by taking the hose off. Trickle the Seafoam stuff into the hose in small doses, allowing it time to burn the stuff out and recover smooth running between doses. Hook everything back up and drive off.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 02-18-2006, 06:37 PM
crazypaw's Avatar
crazypaw crazypaw is offline
crazypaw is starting off with a positive reputation.
Hi TigerDan,
Seafoam is not introduced into the injection / injectors it's just for the intake manifold; to hopefully eliminate carbon build-up?
Tags
1987, 1997, 23, cylinder, e150, engine, ford, lima, problems, ranger, seafoam, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
