In cab(behind the seat) gas tank
If the seals are sold they will leak and stink up the cab. Also, the brass floats sometimes get holes worn in them and the full up with gas causing your fuel gauge to read "empty." Shine a flashlight (not a lighter or torch) into your near empty tank and look for rust and scales forming inside. Clean your electrical contacts to ensure a good reading from your sender.
Originally Posted by Bdox
I would be inclined to install a new tank under the bed.
The one you have is, what, thirty-seven years old and it's taking up space that could be used as secure storage.
Anyway behind the seat isn't for storage its for BIG amps/woofers.
I have that tank. The truck sat for 5-8 years and rusted in the bottom 8 inches probably cause a lot of moisture condensated in there while it sat. The fine rust plugged up the fuel filter twice and would kill the engine. I found a spotless tank in the salvageyard and replaced it. It was a very easy job. You can check yours by taking off the fuel filter canister (it's kind of like removing an oil filter) and check it for rust. The canister is 4-5 inches long. Mine was halfway full of rust dust both times the engine quit running. The brass float also had rotted away (don't ask me why) and a new one is about $6 and real easy to replace.
Those are the problems and they're real easy to fix. Nothing to worry about.
If your keeping the tank behind the seat, replace the fuel filler hose between the tank and gas filler cap. This rubber hose will crack with age and cause gas smell in cab. A rancher friend loves the fuel tank behind the seat..no way it will be damaged when driving rough country.
The newer trucks with the fuel tank back by the rear axle have the frame crossmembers located to make room for the fuel tanks. The older trucks like my 67 don't have room for the newer style OEM tanks.
Originally Posted by JohnT
I've been driving the truck daily for a couple of weeks now, and I haven't had an problems with the gas tank so far, so I'm guessing that my gas tank is in good shape for its' age. I know that the fuel filters were replaced before I bought the truck, and it has a clear fuel filter under the hood so I can keep an eye on the cleanliness of the gas that way. I think my truck has been driven on a pretty regular basis for most of its' life so it hasn't been sitting causing rust and corrosion to accumulate in the tank. I may eventually replace the rubber hose between the tank and the filler cap because it does seem to get a fuel odor in the cab whenever I put gas in it. Also, the gas gauge doesn't always work, but I'm not too worried about that right now.
Originally Posted by workingdog
I have a similar setup in my '68 that I am looking to get rid of. Does anyone have a recommendation for a bed mounted tank that they have used and works well - that is fits easily?
Originally Posted by fitzwell
what wdog said.....i've got a 69, and would like to relocate the tank.....no room for speakers
One big issue is placing the filler. You will have to go through the bed, the side of the body, or maybe through the bumper. While it will free up space in the cab it is not a simple change out.
Tis a shame there was no more room in the cab than there is.
John
johnt, you need the rubber filler neck grommet more than the filler neck itself. What happens on these old trucks is that the gas cap leaks when you make a turn and that rubber grommet isn't keeping the gas out. It is supposed to keep gas and water out of the cab. I replaced both the gas cap and the grommet and now I don't have that smell problem. That smell was killing me after fill ups. The grommets are $10 at dennis-carpenter.com.
