Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad & 4x4
New! Use your Facebook to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-24-2005, 02:07 PM
Skipped_link's Avatar
Skipped_link Skipped_link is offline
Skipped_link is gaining momentum as a positive member of FTE.Skipped_link is gaining momentum as a positive member of FTE.
Lettin the cat out of the bag (power plant)
Well since this is my 300th post I figured I would follow form with a cool post/thread, (though not as cool as fishy's top fuel fact sheet),
Any way as the 49' gets closer & closer to being complete, one major component has been pushed to the side line, as I wanted to get most of the truck done first, the main goal for the engine was based on a couple simple rules
1, had to be natrally asperated
2, one carb
3, 572 ci
4, at least 1000 hp
Well, when I got the money togeather & got ready to order parts I thought to myself, "I hate rules,,, why set them for myself ?"
So after a little shopping around I found this fine example of a big block for a reasonable price, after chatting with the owner & a quick trip to Wichita KS for a good look at it, I loaded up the engine & now have it home,
Here are a couple pics of how it looked when I picked it up,
http://www.ford-trucks.com/user_gall...=96470&width=0
and
http://www.ford-trucks.com/user_gall...=96469&width=0
Details are,
Ford SVO block
3.77 stroke forged crank
Venolia rods & pistons (4.530 bore)
SVO A-460 aluminum heads
The intake is a home made steel unit wich I have already replaced with my own aluminum version,
on top of that is a 14-71 Littlefield high helix delta plate blower & enderle bird catcher injection for the alky,
also included was a three stage peterson dry sump system, I tossed the home made steel pan and fabbed an aluminum one from a stefs front sump pan,
Currently the engine is disassembled, It was just freshend with new rods, pistons, valves, springs, bearings, ect, but I wanted to completely disassemble the engine & check it over, so far all is well,
I have everything I need to reassemble it (except time), right now it looks like the first week in december I will get it all put togeather & set in the truck, then a week or so to finish up the plumbing, hopefully by the end of december we will be lighting it up, I'll post more pics when I have the engine reassembled,
__________________
Top Truck Challenge 09, Challenger #1
http://pirate4x4.com/forum/showthrea...=monster+buggy
Enjoying the high desert & no smog in the Nevada Chapter
  #2 (permalink)
Old 11-24-2005, 02:59 PM
davethecow davethecow is offline
davethecow is gaining momentum as a positive member of FTE.
Dang man your motovated!
__________________
High desert.Mountains.Clean air and no smog.In the Nevada chaptor
75 f-100 short box 4x4 Ford 390,np435,dana20,dana44/60
73 K-10 short box 4x4 Chevy 396,t400,np205,dana44/60
78 w-100 short box 4x4 Dodge 383,np435,np203,dana44/60
81 jeep wagoneer 4x4 401,tf727,Atlas2,Currie rockjock 60s front and rear.
  #3 (permalink)
Old 11-24-2005, 03:09 PM
ivanribic ivanribic is offline
ivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud of
I don't think it really matches your truck at all and that bird catcher isn't gonna clear the hood. Since you just got it all painted why cut it up? Send me that engine and I'll send you mine. It'll easily clear your hood with no problems, you don't have to run alky so you won't be tempted to drink your fuel. Heck, I'll even help you out and pay shipping.
Freakin awesome! I can't wait to see this thing all put together. That truck has been in the making a LONG time.
  #4 (permalink)
Old 11-24-2005, 03:34 PM
I'll keep that in mind if it doesn't work out,
Your right the hood will have to be cut, (so much for the weekend in getting that scoop fit on there), I think there is room on the hat for another sticker though,
As far as drinking my fuel it's funny you brought that up, I was thinking when I get the truck running I'll paint my fuel cans to look like beer bottles,
__________________
  #5 (permalink)
Old 11-24-2005, 07:40 PM
chrono4's Avatar
chrono4 chrono4 is offline
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
wow, thats alot of engine there. looks like its gonna be fun.
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
STGs MinionsTechnical Advisor
  #6 (permalink)
Old 11-24-2005, 07:52 PM
RawPower's Avatar
RawPower RawPower is offline
RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.
i think an I4 would do better than that motor... I've heard you start losing power after 460ci...
jk, thats sweet
  #7 (permalink)
Old 11-24-2005, 07:55 PM
bremen242's Avatar
bremen242 bremen242 is offline
bremen242 is gaining momentum as a positive member of FTE.
dude, that motor is phreaking awesome. so much for being naturally asperated.
__________________
http://mav.wastegate.net
'00 in the drive, '85 F250 that runs, '84 F150 in the weeds, minus 1 '85 F150- I finally got rid of some junk..
  #8 (permalink)
Old 11-24-2005, 08:11 PM
teds74ford teds74ford is offline
teds74ford is gaining momentum as a positive member of FTE.teds74ford is gaining momentum as a positive member of FTE.
I would have posted earlier, but I couldn't stop staring That's going to be AWESOME! I love the work you are doing. I can't wait to see it done
  #9 (permalink)
Old 11-24-2005, 11:03 PM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
I think rob is going to have a some competition in here for biggest motor
Curious, how many ponies is that beast supposed to turn out?
__________________
Cody, Calgary
AB Chapter Leader
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 450hp 400, 4sp/205, 38" tsl's
  #10 (permalink)
Old 11-24-2005, 11:23 PM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.
wow! i am speechless yet again, skipped.
-cutts-
__________________
My Google Photo Gallery
-96 F350 4x4 ZF5 CC/LB, 37" SSR's, D66 turbo, Stage-1's, Banks IC, 5" stacks, York OBA
-72 Bronco 302/NP435/D20/D60/10.25 welded F/R, full hydro, hydroboost, 39"iroks
  #11 (permalink)
Old 11-25-2005, 07:22 AM
Quote:
When I picked up the engine I was told the blower was 46% over driven & made 36 pounds of boost, & over 1800 horse,
The plan is to derate the engine and make it live a little longer,
I have already bought the pullys to make it 25% over driven, we are shooting for 15-20 pounds of boost, & someware around 1200-1400 hp,
__________________
  #12 (permalink)
Old 11-25-2005, 10:22 AM
hotrod48 hotrod48 is offline
hotrod48 is starting off with a positive reputation.
WOW! I love it. I can't wait to see it in the truck. That is about what I want for my 48 someday. Keep up the hard work.
I'm just curious, are your motor mounts higher than normal? The reason I ask is because, I have seen a few F-1's that were blown and everything was hidden under the hood. It would be nice to hide it, just so everyone doesn't know, but I know I would want to flaunt it. It will look awesome.
hotrod48
  #13 (permalink)
Old 11-25-2005, 10:23 AM
Oval_obsessed Oval_obsessed is offline
Oval_obsessed is starting off with a positive reputation.
Wow, it keeps getting better and better. What's next? Can't take too much more.
Skipped,
Great job!
__________________
1994 F150 4x4 300 5sp
2003 Explorer XLT
1985 Bronco in pieces
Member of Illinois Chapter
  #14 (permalink)
Old 11-25-2005, 12:05 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
I think rob is going to have a some competition in here for biggest motor ?
I still got him beat on cubic inches but that thing will make 2 of my engines for power.
skipped, I noticed you mentioned Venolia rods, and pistons does that mean it has alum rods? I don't remember off hand what you say your gonna do with that great looking truck, but just remember with alum rods your gonna need to tear it down atleast once a year to check them for length, and stretch. Also while you have it torn down get a beginning measurement on them so you know how much stretch you are getting.
Also I noticed you mentioned it having a forged crank, are you sure it's forged? or is it a billet unit? up until very recently the only forged unit that could be had was the stock 429 truck units or the Boss 9 which has a different front snout (actually both have different snout even from each other) and offset grind them to the 3.77" stroke. Just curious is all.
BTW that is an awesome looking engine, and will make one heck of an addition to that great looking truck.
__________________
Rob
2000 F250 7.3 psd 1/8th mile 9.35 @ 70.5mph
1967 Galaxie 390 1/8th mile 8.13 @ 84mph
  #15 (permalink)
Old 11-25-2005, 12:27 PM
Rob, it does have aluminum rods, a yearly tear down has always been in the plan, even with N/A motor I was going to build, Good call on getting a rod length while it was apart, I had not thought of that,
I am sure it is a forged crank, I "think" it is an offset ground 429 crank, I am not sure what snout they had but this one looks like a bbc diameter, and a little shorter than a stock 429/460 snout, also it only has one key way instead of one timing key & one woodruff key for a dampner,
compairing snouts this one is huge compaired to the stock unit,
after a close inspection I can see that it is internally balanced, there is a mallory slug at both end of the crank,
When I get to a good point to take some pics, I'll post them so you can see the crank, it is a very nice looking piece,
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
