grinding noise when defrost is on
I know the compressor kicks in and out when using defrost, however this is a weird grinding type noise as the compressor kicks on/off.
The truck is new to me...just bought it used. It's a 2000 Lariat. I'm assuming its a bearing in the compressor, but thought I'd ask if anyone else has run into this sound b4? Or could it be a belt pulley that the bearings are going out on and the load of the compressor kicking on/off is what is making it make that sound? Any suggestions on how to pinpoint it...I can't tell if its coming from the compressor itself or the idler pulley (I think that is what it's called).
Doe's it make the noise when the compressor is engaged or disengaged? If it does it only engaged, the bearing most likely isn't the problem. If it does it disengaged or it doesn't matter, it may be the bearing. Remove the belt and spin the pulley and see if it seems rough, if it does, the bearing is the problem. Just be aware, it can also be the tensioner pulley or the idler pulley, when you have the belt off spin these also and check them.
1956lando
01-12-2013 11:45 AM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
07-17-2009 01:35 PM
Mayerstom
03-29-2009 01:57 PM
