idling poor/stumbling while accelerating
Hello. While surfing the net looking for some trouble shooting guides to help diagnose an issue, I came across this website. After reading several postings I decided to join. My name is Keith and have a 2002 F150 4x4. Just this morning, the engine started idling bad and would stumble during acceleration. It's got 61k miles and my original thoughts were bad gas or maybe the typical tune up stuff. However, after reading a few different postings regarding missing or hesitating, I'm now concerned that it could be a compression issue. The stumbling was so bad infact, that the entire truck started shuttering (3 different times).
Any ideas?
Any ideas?
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site. https://www.ford-trucks.com/forums/s...d.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
I have 49,000 miles on my 02 F150 5.4 and my fuel pump died just like that. One minute it worked the next time i started the truck it was dead.
Two days prior to the fuel pump dying, the engine was ideling very rough when sitting at a red light. It cleared up and no check engine light came on. So i didn't think anything of it until it died 2 days later.
Things to consider:
your fuel pump, fuel filter, or look for a vacuum leak. Good luck, check back with your progress.
Things to consider:
Originally Posted by FordFrenzy97
Mine does the same thing. What the hell is a spark plug ejector and where is it?
Check your plugs, its a pain, but its gotta be done. If you find that one is loose, tighten it back up and squirt a thin bead of silicone around it. This will help prevent the same issue again, as well as prevent water from getting into the engine. When my plug got loose it was during those two weeks of crazy rain a couple months ago and water managed to get into my number 1 spark plug chamber and foul up the engine. It turns out that water doesn't compress very well. Thank god for my warrantee. The silicone bead trick was recommended to me by the dealer who had seen 2 similar issues within that same week on our same engine.
The silicone isn't necessary but I had him do all the plugs anyway as I did not want my built Ford tough F150 put out of commission by a large puddle again.
AJ
Hello everyone!!! My first post.
I have a 97 F-150 with 126,000 miles on it. The only problem I have had with this truck was the universal joint had to be replaced until now. I was in Cape Hatteras in October when a tropical storm breezed through. Well as most will know, some of the island was flooded. I went through the water trying to wash the sand out of the bottom of my truck when the "check egine" light came on and started blinking and skipping. I had someone check the code and it said, "#1 cylinder lean". Sometimes it runs good and smooth but mostly runs rough. I replaced the spark plugs and i'm about to replace the wires. Any help would be greatly appreciated!!!
Thanks
Randy
Dry Fork, Va
rmobr549@hotmail.com
Thanks
Randy
Dry Fork, Va
