17-16" wheel change possible?
I believe they would be O.K. I have a 2001 which came from the factory with the Sport option which included 17" wheels. Since they were optional, I was fairly sure that the standard 16" wheels would work, and they do. My snow tires are on the 16" wheels.
Mine is a 4x2, but I think yours would still work similarly.
One thing to check for is if there will be clearance issues betweeen the inside of the wheel and your brake calipers. It is not too often that you can go down a size. But since the two sizes were offered for these trucks it may work. Just go to a tire/wheel shop and have them pull out a 16inch wheel. You dont have to mount a tire or anything, just place it on the studs and make sure it will clear the calipers.
