Tone Ring Replacement
Old 09-06-2016, 11:44 AM
motorcarmike's Avatar
motorcarmike
motorcarmike is offline
Hey all,
After some investigating, i have found that the tone ring on the passenger side is split which is causing the ABS to kick on at low speed every now and then.
I have replaced a tone ring on an escape, i am just wondering if its a similar job to do on the econoline. after looking on rock auto, im not seeing just the tone ring. maybe i have to replace the whole hub?
any help or suggestions would be great!
Thanks
Mike
Old 09-07-2016, 08:12 PM
motorcarmike
really? none has had to fix a broken tone ring?
Old 09-07-2016, 09:14 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
I promise you some people would have chimed in by now if they have similar experience.
I think you're all alone on this one
What kind of van do you have? I'm about to change my rotors and I can try to carefully remove on of my tone rings and send it to you.
Old 09-07-2016, 09:32 PM
motorcarmike
wow im surprised! maybe i call ford and see if just the ring is available or if i have to buy the whole hub.
If you wouldnt mind taking a photo of how the ring is mounted, that would be great!. theres not much online and i dont want to pull my van apart just to see.
its a 2010 e250 with a 4.6
Old 09-08-2016, 05:03 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
Mine is a 07 E350 with V10. I think there was a factory brake redesign/upgrade in 2008, therefore I suspect our brakes are not interchangeable.
Old 09-08-2016, 04:51 PM
motorcarmike
So i did some digging. yes, the tone ring comes on the rotor/hub when you buy the assembly. The ring alone is $79 CDN i think ill just wait and but the whole assembly when my rotors are dead..
Old 09-08-2016, 07:57 PM
vettex2's Avatar
vettex2
vettex2 is offline
makes sense
VORTMAX_99
1999 to 2016 Super Duty
30
11-26-2016 12:16 PM
Robert Clamage
10-18-2016 03:16 PM
run6.0run
39
01-20-2012 09:27 AM
kidoo
09-23-2011 11:25 AM
4xfordbronc
1978 - 1996 Big Bronco
01-13-2004 05:46 PM
Quick Reply: Tone Ring Replacement
