Question: How to find a vacuum leak??
Howdy everyone. I have a 98 Ranger, 4x4 extended cab, about 170K miles on her.
Short version of a long story, the temperatures are now cooler, and I started getting P0171 & P0174 codes. Had the same issue last year, problem goes away when spring/summer returns.
Looking through earlier posts, most folks suggest cleaning the MAF, which I will do this weekend. However, failing that, another suggestion is checking for vacuum leaks. What is the best way to check for one? How might you find its location?
Thanks for any help and advice
in my haynes manual it talked about how to do it and what the vacuum pressure would be because i tested my old 92 before. you might be able to find somethin on the net on how to test it but i always have a hard time looking stuff up with pop up ads and always getting led to totally wrong sites.
Yes you can find them with the carb cleaner or wd-40 ect ect. I also have had good luck listening for them. I took one of my old engine stehoscopes and put a piece of 1/4" copper tubing in place of the rod and then I start probing with this when you get close to the leak you will definitely hear it.
The rain and wind finally stopped.
Started poking around for vacuum leaks. Squirting carb cleaner around vacuum line connections didn't do a thing.
Looked at the 3/8 fuel line that runs from the throttle body to some sort of modulator (EVAP part I think). The outer coating of the tubing would just crumble as you bent the tubing. Replaced it.
Also found that the throttle cable was rubbing against a plastic vacuum line. Can't find a replacement for that - have a seperate post for that issue.
Will just keep watching to see what happens next.
98-Ranger
1983 - 2012 Ranger & B-Series
11-24-2005 05:19 PM
KYFord
06-14-2004 01:14 PM
