F150 Seat Belt warning noise
does anybody know if its possible to disconnect the highly annoying seat belt warning noise? And before everyone starts telling me to just go ahead and put the seat belt on, I appreciate the concern for my safety, but I make alot of frequent stops around town and this noise is beginning to drive me crazy!! I wear my seat belt just about everywhere, but its not practical all the time.
It seems like it is louder than other Ford trucks, a little to loud for my ears. Also, when there is a passenger in the car, and they wait for you to run into the store, it continues to go off and they are subjected to listening to it until you return.
Any information is appreciated.
I would like to shut my belt minder off also. I know the manual tells ya how to do it but I just got my truck on 11/15 and haven't had time to read the book yet. I know on the super duty I had to turn the key on and off a few times while conecting and disconecting the buckle in the right order.
There are 2 ways you can disable the beltminder. 1.for a 1 time disable if the driver/passenger quickly buckles then unbuckles the beltminder is disabled for that ignition cycle on. there is no confirmation given for 1 time disable and you will have to do this each time ignition is turned on/off or when the belt remains buckled for more than 30 seconds. The 2nd way is permanent unless you activate it yourself. before the procedure make sure parking brake is set, gearshift in park,ignition off,all seatbelts unbukled.
1. Turn ignition RUN or on but donot start
2. Wait until safetybelt warning turns off
3. Must be completed within 50 secs after light turning off.
Buckle thenunbuckle 9 times ending in the unbuckled postion
4. after step 3 the airbag light will turnon for 3 secs
5. Within 10 secs of light turning on buckle then unbuckle the belt.
This should disable the belt minder and The Airbag light should flash 4 times per sec for 3 secs.
Hope this works for you. The driver and passenger seat are indepedent of eachother so to disable passenger repeat same procedure w/that buckle.Good luck
T0DD
1997-2006 Expedition & Navigator
09-27-2004 02:12 PM
