Can Anyone Recommend a Good Floor Jack?
Originally Posted by BillyBob69
Try to get one with a "Quick Rise" lever. It is nice to get the jack in contact with the truck quickly then you can raise it normally. Otherwise you are pumping the handle for a couple of minutes before it gets to the truck.
I am also in the market for a jack. Ours is a 3 ton, but it has a leak in it, so after it goes up about a foot, each cycle of the lever only gets it about 1/4" higher.
Anyone know of a good 3+ ton jack that will reach higher than 30" or so? I plan to put 33's on my truck soon, and my current jack wont get my 32's off the ground unless there is a 4x4 wood block on it.
