Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-20-2005, 04:36 PM
BACWUDZ is starting off with a positive reputation.
Question on cleaning MAF
What or how do you clean the MAF? carb cleaner squrting a very little at a time 12-14 inches away and then blow it off with the air gun the same distance? all help is appreciated.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-20-2005, 05:41 PM
kspilkinton's Avatar
97-03 250LD/7700 Guru
kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.
Autoparts stores sell car electronics cleaner, basically it is pressurized alcohol. Never put any other chemical on the filament of the MAF and down blow it away with HP air. It's a platinum thread that uses minute resistance changes to calculate air flow, pressure, and density, and you'll ruin how it performs it's job using a petroloeum based solvent. Don't physically touch it either. I can recall a story where the guy used a swab and then had to spend $300+ to replace the sensor.
To clean it correctly, you have to unplug the MAF, remove the tamperproof torx heads (they sell the driver at parts/ hardware stores) then take the MAF off the intake. Spray the automotive electronics cleaner at the filaments, seperately, there are two. One filament hides behind the big plastic chunk to act as the reference leg for the system.
Allow a few minutes to dry and reinstall.
-Kerry
  #3 (permalink)
Old 11-21-2005, 06:05 PM
350z is starting off with a positive reputation.
Ive always used 92 % rubbing alcohol in a spray bottle safe but effective.
__________________
04 F350 5.4l auto 4x4 sc sb lariat,buckets,4.10LS, plow,camper/overload springs/rear sway bar,FX4,pwr pedals&slider,backup sensors,heated/lighted mirrors,cab lights,Gibson stainless exhaust,FTVB,6"superlift w/diesel springs,35's,bilstein5100's,alarm/remote/pager,undercover
  #4 (permalink)
Old 11-21-2005, 07:32 PM
Quote:
That will work, probably cheaper than the electronics cleaner too.
-Kerry
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
