AIC wiring
AIC wiring
Does anyone have a wiring diagram/pinout for connecting up an AIC module?
I have the control head but not the harness, it has a 6 pin plug on it that I think connects to a harness under the dash. Doesn't seem like it would be
too hard to solder in the appropiate wires between the AIC & the connector.
I just don't know which wire goes where. Truck is a 97 PSD.
Thanks
Thanks
It helps some but my AIC module has a 6 pin conn, the manual shows a
4 pin. Is the 18 pin connector shown in the manual the data link (OPBII)
conn.? Doesn't the factory AIC harness just run from the AIC to a 4 or 6 pin conn under the dash? Where does the data link conn fit in? Is it just easier to get to?
Al, yes it is real easy to get to, as if you put your head down by the throttle, it is visible and right there! Kind of towards the hump in the floor, but closer to the drivers side.
As for how many pins...I've had mine in so long, I've forgotten how many pins where on the truck side of the connector!
I also revamped the mount (usually they come with a mount for the Superduty) to fit nicely under my dash.
Anyone wishing to see some pics of how I mounted mine (not sure if they will help?), they can be seen at http://community.webshots.com/user/powerstroke2010 and you can see how it is mounted as well as some side shots.
Dale
Dale
GGraves
11-11-2016 08:29 AM
