98 E350 no heat - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
98 E350 no heat
Old 11-19-2005, 08:52 PM
joe35098 joe35098 is offline
joe35098 is starting off with a positive reputation.
98 E350 no heat
Blower works & was just blowing cold air. Not sure if the t-stat or the water pump was bad I replaced the t-stat & now it blows only hot air all the time.
Just as it did before I replaced the stat, the upper radiator hose was warm and the lower cold.
If the water pump was bad wouldn't the engine overheat? The temp gauge reads normal & rises normal from cold starts.
I am happy to have heat again but it would be nice to regulate it again.
Any ideas would be appreciated.
Old 11-20-2005, 07:43 AM
camarokid81 camarokid81 is offline
camarokid81 is starting off with a positive reputation.
check the diverter door in the air box (ac to heat) inside van pasenger side front under the dash. ford has problems with the air box 97-99 in the vans. i had to replace one in a 97 van. the part was 200 from the dealer. the replacement part is for 2000-up. this should have been a recall. i talked to the parts guy at the ford dealer he told me they sell so many of these they cant keep them in stock. when you move the control for ac and heat on the dash it moves the door in the air box.(little electric motor) if it is working you will hear the door slam into position both ways (door up-door down) it might be jammed (stuck half way) move the control to ac and back to heat a few times might un jam it. the door on mine jammed and then broke (hinge) your water pump should be fine (no leaks and not froze up) try what i put in this post and let me know what you find. i will help you as best i can.
Old 11-20-2005, 12:02 PM
Thanks
Thanks for the info camaro.
I will check it out.
Old 01-13-2006, 03:36 PM
warryan warryan is offline
warryan is starting off with a positive reputation.
Is the control for the diverter door manually or electrically or vacuum controlled, or what in my '97 E-350? The temperature control is the dial type, not the slider type. I don't hear any noise when changing temp from hot to cold. The rear heater is working fine, but it sure is cold on the driver's feet!
Old 01-13-2006, 06:51 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome joe35098 and warryan, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 01-17-2006, 09:09 PM
Adventure Adventure is offline
Adventure is starting off with a positive reputation.
That means your blend door is either broken (common problem), or the gears are stuck (another common problem). If you look up under the dash board, on the passenger side, all the way to the left, look up high, you will see a white gear box and motor assembly. Tap on the box and if it is just the gears, the tapping will loosen them and you will get heat again. I've been doing this now for about 3 years.
cooling intermittant overheating thomasiovino Excursion - King of SUVs 9 11-12-2014 05:21 PM
Cheap thermostat: The Aftermath!! Hazard85 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 03-18-2014 12:26 PM
05 6.0L - heater blowing cold/hot/cold/hot nkm 6.0L Power Stroke Diesel 1 03-03-2014 12:31 PM
problem with degas overflowing Buddy03 1999 - 2003 7.3L Power Stroke Diesel 15 06-04-2012 09:16 AM
Need help!!! 390 running very warm/hot MAHinton FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 02-19-2004 02:03 PM
Tags
1998, 97, 98, ac, back, blower, blowing, diverter, door, e350, ford, front, heat, high, rear, replacement, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
