Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Oklahoma Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
  #1 (permalink)
Old 11-18-2005, 10:04 PM
mike2112 mike2112 is offline
Garage is empty, add now
mike2112 is starting off with a positive reputation.
Unhappy RABS light won't go out
OK, I've posted this elsewhere and gotten very little response. Maybe someone more "homegrown" can help out.
Nothing new here, just an ABS light that won't go out. I have read through all the ABS posts and am still perplexed. 1987 F-150, 302, 2WD, auto. Here's what happens: turn vehicle on, light comes on for a couple of seconds, then goes out for a couple of seconds, then comes on and stays on. I hear a little click when the light goes out. I have replaced the speed sensor with a new one from Ford, I have checked the wiring from the speed sensor, and have checked the wiring at the master cylinder. When I ground the black/orange wire, I get no codes. The light does not flash, it is just on. All other lights are OK. I have read in other posts that the black/orange wire connects to a red wire. I don't seem to have such a red wire. My black/orange is just hanging out there by itself. Could this be causing my light to stay on? Where the hell is this red wire? Where does it go? Where has it gone? Also, coming out from the side of the truck, next to the emergency brake, is a lt.blue/black wire that looks like some test connection. Any clue what this is? Thanks for any help. Phantom lights really put me over the edge.
Click the image to open in full size.
  #2 (permalink)
Old 11-21-2005, 06:04 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader SwOkcOffRoader is online now
1952 Ford F-1
My Garage
SwOkcOffRoader is gaining momentum as a positive member of FTE.SwOkcOffRoader is gaining momentum as a positive member of FTE.
well, i dont know diddley about ABS systems, but i can share an experience with ya...my mom has a 92 Ford Aerostar minivan, and the rear ABS light came on one day...i couldnt find anything wrong with the brake system what-so-ever, i was losing my mind over the matter..well a couple days later her battery went dead...turned out the alternator was bad and low voltage in the system caused the light to come on....i have come across this before, sometimes low voltage can cause the "idiot" lights to do strange things....im not saying this is YOUR problem, but you might look into it just in case....good luck with it.....
__________________
Why is there never enough time to do it right the first time, but always enough time to do it again??
....Will work for Rep points....
  #3 (permalink)
Old 11-22-2005, 09:13 AM
cigarxtc's Avatar
cigarxtc cigarxtc is offline
cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.
Heya Mike, I also would have no clue there. But my two guesses would be to first flush and fill with new brake fluid and give it a 15minute highway and city test run. Then my second thing to try would be to physically disconnect every wire connector inline from the ABS light down to the sensors one by one, and spray them with electrical contact cleaner spray as you work your way down. Then give it another test run on the street. My thinking is if there is any crud in the brake fluid on any of the sensors or if there is corrosion or dirt in the electrical wire connections that may be causing it. But that is just what I would do.
__________________
-Ron
Daily Driver 1978 F150
  #4 (permalink)
Old 11-22-2005, 05:19 PM
Silver Streak Silver Streak is offline
Silver Streak is gaining momentum as a positive member of FTE.
Pull the diff cover off and see if the tone ring is contaminated with crap. If the teeth get filled with sludge from the rear end the sensor has trouble reading the gear. It's probably time to change the diff fluid anyway.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
  #5 (permalink)
Old 11-23-2005, 01:21 PM
rogerf100's Avatar
rogerf100 rogerf100 is offline
rogerf100 is starting off with a positive reputation.
I had an ABS light come on in a 1991 Aerostar that had rear ABS. It was a bad sensor but also the rear brakes would lock up in a hard stop. I replaced the sensor and it was back to normal braking.
__________________
RogerF100
True blue Ford fan
'55 F100 with '64 292 V8 3 deuces
'94 F150 Flareside
roger dot hughes64 at gmail dot com
  #6 (permalink)
Old 11-25-2005, 06:03 PM
Thanks for the suggestions. I have quietly been suspecting the ring in the diff. I changed the fluid about 10K ago, but didn't look inside too closely. I'll try the wires, too. God, I hate wires and lights!!! This light has been on for years. It's amazing that a system so notorious for being so problematic can have a bulb that never burns out, even when it is constantly on. Go figure.
Tags
abs, amber, connection, f150, ford, light, location, rabs, rear, stays, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
