Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aftermarket Products SPONSORED BY:
  #1 (permalink)
Old 11-18-2005, 10:00 PM
ajstephan's Avatar
ajstephan ajstephan is offline
Garage is empty, add now
ajstephan is starting off with a positive reputation.
Rear Collision Avoidance System
I recently heard that they sell aftermarket rear collision avoidance systems for a couple of hundred dollars now. Since I have a young granddaughter and live near a school, I'm looking to get one. I heard that Audiovox sells one that fits in a receiver (http://www.audiovox.com/webapp/wcs/s...4768&langId=-1 ) but I don't know much about it or what the real cost is. There's results from a google search on price, comparisons, etc.
Has anyone else looked into these?
  #2 (permalink)
Old 11-19-2005, 12:04 AM
CobraXP's Avatar
CobraXP CobraXP is offline
CobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to behold
I didn't get it as an option in the wife's 05 Escape Limited, but have been thinking of getting the kit and adding it. I haven't looked into which brand to get, but I have seen a few threads on FTE where people have added them. You might try a search for 'back up sensors' and see what comes up. I do know a few that have added them and they have said they are not hard to install.
Might be a good time to research them myself...
__________________
David
FTE Super Moderator
Join us in the Utah Chapter!!!
When you can't buy what you want, build what you want.
  #3 (permalink)
Old 05-19-2008, 06:28 PM
jfpaul jfpaul is offline
jfpaul is starting off with a positive reputation.
After Market Product - Reverse Sensing
I know it has been a while since your post, but try Crimestopper, Backstopper CA 5012. For about $60, it is the best value for the price. Easily installed, wireless from the bed to the cab and extremely accurate. Gives audible, graphic and distance measures to object, within inches. If on the F150, you have to drill four holes, but the bit is included. Two go into the metal bumper, two into the plastic next to the license plate. Go to a dealer, find a truck with OEM reverse sensing, measure and use that for your template. Make sure to paint the holes in the metal with primer or touch up paint before installing the sensors. This will help resist rust. There is plenty of room and openings to snake/run the wires in the rear and seat them inside one of your rear lamp housings. You can wire the readout in the cab into your fuse box. I have the Lariat and put the read out right infront of the floor mounted shift. Overall, the install took about 1.5 hours. I installed mine in January 2008 and have had no problems. Has saved my "butt" several times since it is very difficult to see what is behind you. Good luck ajstephan.
  #4 (permalink)
Old 05-19-2008, 07:56 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
For about $90 you can get a rearview camera from pep-boys (don't remember the brand, and I'm sure you can find it other places) The camera fits over the licencse plate frame, tap into power and ground and it send a wireless signal to a small color LCD you can mount anywhere in the cab. You can hard wire the screen or just plug into the cig lighter. I think you can wire it into the backup lights so it turns on automaticly when in reverse. I got one for my Dad's E350 cargo truck (now that's a blind spot!) and the wireless signal is right on the limit, so it gets a little snow sometimes, but it should work perfect in a regular size vehicle.
__________________
2002 F-150 Supercab 5.4 Triton V8
Arizona Biege
  #5 (permalink)
Old 05-20-2008, 07:35 AM
Had one of these from Costco's and yes snow, dirt, darkness all affect it. Took it back after 3 months and purchased the Backstopper system. Much more effective.
  #6 (permalink)
Old 05-20-2008, 02:40 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to all
Echomaster also makes a good sonar system, it resembles the OE system in the superduties. The sensors are a little involved to install, you have to drill a hole through the bumper and any reinforcement, then figure the angle shims you need. The rest of that kit is easy, mount the brain and speaker. The speaker will have a switch to turn it on and off.
It's expensive, but the nicest finished product. I once tried a kit from the hoffman group called Stellar. The sensors had a flange on them with screw holes that you see when it's bolted on the bumper. I wasn't impressed with it.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #7 (permalink)
Old 05-20-2008, 06:19 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
I've used all three, although in limited quantaties:
--GOAL (get out and look). Works well, pita.
--Bubble mirror. Works OK, sometimes requires GOAL. L.L.S.
--Radar/beeper. Works OK, requires GOAL more often than BM due to false readings, but once you get used to it, acceptable.
--Camera. Almost perfect. You'll get out and brush off the lens far less often than you will get out to check using the other systems.
jmo/ymmv
Tags
aftermarket, avoidance, avoidence, backstopper, backup, ca5012, collision, ford, installing, rear, system, systems, truck, vehicle, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
