Identifying axles and gear ratios on a 1974 f250!! - Ford Truck Enthusiasts Forums
Old 02-27-2002, 10:20 PM
my74f250 my74f250 is offline
my74f250 is starting off with a positive reputation.
How do I go about identifying what I have!! I would also like to know how to identify the trans and the transfer case! I think I have a pretty good Idea of what I have but would like to make sure!! Thanks
Old 02-27-2002, 11:17 PM
bigbrownie bigbrownie is offline
bigbrownie is starting off with a positive reputation.
The rear and front end are probably danas, and they sould have tags on the side of the pumpkin cover,it will say D4.11 or something like that. Thats your ratio and if Im not mistaken it also says D4.1160 which would be 4.11 ratio dana 60's. As far as transfer case and Transmission I dont know too much about. I know theres a different shape to the pan on the c-6. Maybe someone else can help you with that. Sorry I couldnt.
Old 03-02-2002, 01:34 AM
jsworkman jsworkman is offline
jsworkman is starting off with a positive reputation.
On the right side axle tube there should be a number stamped in the tube this is the bill of materials number a ford dealer should be able to tell you how your axles came loaded from the factory or post them here and I can check them in my Dana Spicer axle book.
P.S. check both tubes
Old 03-02-2002, 09:11 AM
Art Art is offline
Art is starting off with a positive reputation.
If the axles weren't changed, you can use the axle code on the door tag to identify the axle ratio and a whole lot more. If no tag, rotate both tires one revolution (same direction) and count the number of driveshaft revolutions. If you can turn only one tire, rotate it two revolutions while counting driveshaft revolutions.
From what I've seen, the front axle is most likely a 4.09Dana44 and the rear axle a 4.10Dana60. Axle code for 4.09/4.10 is A4 ("locking" rear diff) or 24 (open diff). I think that was the standard ratio from about 67~77, with steeper gears (such as 4.56) being optional.
The transfer case is a NP205 if the truck originally had lockouts on the front axle. The transfer case shifter **** reads 4L N 2H 4H with a NP205. If the truck did not have lockouts originally, it has the NP203 transfer case.
The transmission is most likely a NP435 if the truck has a 4speed, or a C-6 if the truck has an auto trans.
I'll bet you the engine is/was a 360 ("Y" letter for 4th character on VIN).
Art
Old 03-03-2002, 07:23 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
I'm perplexed, Why would you have to turn the wheels two turns if it isn't a limited slip diff ?
ONE revolution should give the ratio regardless of it being Locking or non-locking.
Dennis http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver, Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old 03-06-2002, 07:55 PM
Art Art is offline
Art
Old 03-06-2002, 08:33 PM
gr8199 gr8199 is offline
gr8199 is starting off with a positive reputation.
Identifying carburetor '73 f250 w/ 460 73richards250 1973 - 1979 F-100 & Larger F-Series Trucks 16 10-13-2016 01:28 PM
How to identify engine Try this Ford New Member Introductions 1 02-12-2016 04:16 PM
Identify Transmission walksLikeBear Ranger & B-Series 3 08-17-2015 01:31 PM
help identifying transmission anthonym92 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 06-10-2015 03:16 PM
identifying a 391 bradknows Southwest Region 0 01-06-2009 08:15 AM
Tags
1974, axle, axles, f250, ford, gear, ratio, rears
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
