Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
  #1 (permalink)
Old 11-17-2005, 07:57 PM
mnbf mnbf is offline
Garage is empty, add now
mnbf is starting off with a positive reputation.
Duraspark upgrade
Ok so im doing the duraspark upgrade and Im running a carb off a 302 with 1.08 venntrui as well what kind of problems did you guys run into while doing the swap? mine doesnt seem to want to start untill i retard the timeing alot... but once it fires up i set the timing and then turn it off and it wont start again... do i need to change the jets in the carb? is there a trick to timeing it ? once it runs it seems to idle high and even when i get it to ide down it doesnt want to start after i get it set right... is there a trick to this? is the carb the problem? thanks
Tags
duraspark, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
