A couple of questions....
Old 02-19-2002, 11:31 AM
Blaine's Avatar
Blaine
Blaine is offline
Old 03-06-2002, 10:49 PM
JoeyH's Avatar
JoeyH
JoeyH is offline
Ok I am rebuilding my 460 in my 78 F-150, it has 36inch tires and a
C-6 tranny with a B&M shift kit in it... I am boring it .40 over and putting the rebuild kit out of summit in it... I have pete richmond timing gears for it.. my question is what cam do I need... I want it to have a noticable lobe to it but still retain the stock torque converter... also.. it has an offenhouser port o sonic intake and a 750 edelbrock carb on it... and a 3in. exhaust with one chambered flow masters on it...
my other question is... does anyone have or know where I can find a wiring diagram for a 78 F-150????
please help guys...
thanks
Old 03-07-2002, 03:19 AM
THE FORD's Avatar
THE FORD
THE FORD is offline
Hey, hows it going. I recommend the Comp Cam Xtreme 4x4 there are four to choose from. They go from stock, mild, performance to high performance. I think number two, the mild cam, would work great, its the largest cam you can get and keep your stock converter, great for 4x4 and will have that lope to it, hope thats helps a little.
THE FORD's Avatar
THE FORD
THE FORD is offline
Priced around $120
Old 03-07-2002, 08:45 PM
JoeyH's Avatar
JoeyH
JoeyH is offline
thanks for the input...
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: A couple of questions....
