New Twin Turbo Engines On Dealer Lot - Page 3 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
  #31
Old 01-08-2006, 04:12 AM
NickFordMan's Avatar
NickFordMan NickFordMan is offline
NickFordMan is gaining momentum as a positive member of FTE.
You've got it backwards. With a smaller feeding into a larger, you can achieve much greater throttle response, and directly more low RPM torque. The smaller turbo will spool much faster, and will feed the larger turbo, which will create a fast spooling, high volume boost system. This is the best route to go in my opinion.
  #32
Old 01-08-2006, 03:57 PM
PAUL351W PAUL351W is offline
PAUL351W is starting off with a positive reputation.
The new caterpillar ACERT engines have 2 turbos in series, with the smaller feeding the larger, so it would make sense for IH to do the same thing.
  #33
Old 01-08-2006, 05:22 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Welcome to the site PAUL351W
Check out our local chapters at the bottom of the main page to talk to Ford Owners around you!!!
  #34
Old 01-08-2006, 11:16 PM
Aarkie Aarkie is offline
Aarkie is starting off with a positive reputation.
You may have to do it that way for throttle response. If you have a two stage centrifugal compressor the first stage is the largest for a higher flow and the second stage is smaller for higher compression, both stages turning the same RPM. That is what I am use to seeing and it don't sound right the other way. But I guess it works. Do they both turn the same RPM?
  #35
Old 01-11-2006, 06:29 PM
1970Custom's Avatar
1970Custom 1970Custom is offline
1970Custom has a good reputation on FTE.1970Custom has a good reputation on FTE.
I must say that first ford concept, the Reflex is pretty good looking IMO.
I myself am not looking into a diesel yet, but just reading about the introduction of a DT diesel is pretty wild considering only 20yrs ago most diesel trucks were new to the market and non turbo, now we've got TWO turbos mounted onto a V6 and its a factory job. IMO thats a bit of a wow factor.
  #36
Old 01-12-2006, 11:39 AM
gbirky gbirky is offline
gbirky is starting off with a positive reputation.
In series turbocharging, the smaller is dubbed the high pressure turbo, and the larger is the low pressure turbo. On the compressor side, the larger feeds the smaller. On the turbine (exhaust) side, the smaller feeds the larger. The turbo is a volumetric device - requires larger wheels for larger volumes (lower pressure) and smaller wheels for the same flow at higher pressure.
twin turbo exhaust, compound intake possible? parkland General Diesel Discussion 0 03-25-2014 12:50 PM
DONE: Supercharger / Turbocharger: Why supercharge or turbocharge your vehicle? BigF350 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 11 11-06-2012 05:44 PM
New Lawsuit Involving F-150 Diesel origcharger 3.0L Powerstroke Diesel 111 01-08-2009 11:57 AM
The new 6.4 is made by....?? 5.4AZ4X4 6.4L Power Stroke Diesel 245 12-26-2006 10:15 PM
v-6 powerstroke someday General Automotive Discussion 23 03-27-2004 01:00 PM
Tags
engine, ford, truck, turbine, twin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
