strange whistle when very cold out
when i start the truck when its real cold....even if it is plugged in, it makes a intermitten whistle. usually about 1500-2000 rpm. sounds like its from the turbo. but when it reaches normal tempreature it stops whistling and runs normal. its a 95 250 psd. 177,000 miles . i would appreciate any help on the subject. thanks
npriceshoeing.com
npriceshoeing.com
another thing also with the EBPV is that they can sometimes leak a large amount of oil while it is open in the cold. As this is my case at this time that in the morning I generally let mine warm up for a couple minutes before I take off in the morning and then when I get to my destination I stop and there is quite a puddle of oil there. I do have the parts fix this however it will take a better part of a day to do and then of course there is my new problem that is I lost my front passenger side wheel bearings while going 65mph down the freeway.
The first time my wife notices the sbpv kicking in, I was at work and she caled me there telling me there was something wrong with the truck. "Sounds really load and looses some power, but it goes away for a bit if I push on the go pedal." I wasn't sure, but then within the next week, it happened to me as well. I just started to laugh. Last year, when it was cold, I still had a full exhaust system so it wan't very noticable. This year with the open exhaust, it double the sound. Just sounds like a jake brake on a big truck.(well not quite)
Don't worry, it's perfectly normal. once the truck is warm, it's business as usual. Open your exhaust up and then it will really be noticable.
I've been reading all I can about this EBPV and have a question. Is it normal when the engine is cold and driving that the EBPV opens and closes? This happens mostly at part throttle. The truck hisses and surges when this happens. It all goes away once it is completely warmed up or if you stick your foot into it. Or is the EBPV suppose stay at a part closed position and gradually open, kinda like a heat riser valve on the exhaust manifold of a gas motor.
I just bought the truck used, it is a 99, PSD, F350, CC, 6 spd, 118K miles. I have a 99, PSD, E350, auto, and it doesn't do this.
I see this is not in the correct forum section for my year but didn't really want to start a new thread.
Thanks
Thanks
Thanks
Thanks
https://www.ford-trucks.com/forums/s...d.php?t=430880
