Extended Cab 8 foot bed a rare option? - Ford Truck Enthusiasts Forums
Old 11-16-2005, 10:05 PM
BltFordTough's Avatar
BltFordTough BltFordTough is offline
BltFordTough is starting off with a positive reputation.
Hey guys,
I was looking around for a used truck and would like to get a extended cab with an 8 foot bed. Only problem is, I have not seen one for sale yet ??? Is this a rare option, or am I just not finding any?
Did a little research and found a picture of one.
NOTE: Did a some more looking and noticed that I was only searching for the v6 5-Speed 150's (which I want) Could you not get a ex cab long bed with a v6 or manual???
Old 11-16-2005, 10:58 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
The longbed is not very popular, so it will probably be a little hard to find. Not sure if you can get the V6 5sp with a long bed.
Old 11-17-2005, 10:31 AM
roadgrime roadgrime is offline
roadgrime is starting off with a positive reputation.
I see a few of them around. When i bought my 98 sc short bed a few weeks ago i had my choice between the 4.6 sc short bed i bought or a 98 sc long bed with the 5.4 price was within 500.00 and both had about 80k on the ticker... so they are out there u just have to watch... or you m ight try (if you are willing to travel) some of the websites like cars.com etc to try and find one.
Edit Sorry Didnt see you wanted v6 -5spd
Old 11-17-2005, 03:37 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.
The truck is not entirely rare, just a way uncommon.
Here's what I've noticed about the S/C long beds: Most of these trucks were built as work or XL models, so usually they are pretty banged up, contractor used, trucks.
As far as a V-6 5 spd.... well you're looking at an uncommon truck as it is, specific options may be harder to find. I'm fairly certain they were built, but the truck weighs a bit more than the 4200 lbs than a bone stock, reg cab, XL, 4x2, with 6ft bed. They added two more crossmembers underneath as well as the cab and bed stretch, so figure about 750-1000 lbs. If you plan on hauling anything over 500 pounds in the bed, it'll be a struggle... not to mention the towing and payload capacity are greatly reduced because of the M5OD transmission. You may need to broaden your search.
Do you have a specific need for the V-6, 5spd, S/C, w/8ft bed?
Edit: Just found that Ford did not offer a V-6 in the 157" WB trucks from 2000-2004 (Heritage)... this includes the V-6 in a S/C with 8ft bed.
Look at the link below.... may have to navigate some, but It may help you find other info. It's the Ford factory body builder site and gives a lot of technical details.
http://www.fleet.ford.com/truckbbas/
-Kerry
Old 11-17-2005, 04:02 PM
whimsey whimsey is offline
whimsey is starting off with a positive reputation.
For my work I needed a S/C long bed and wanted a manual tranny and 4X4. No luck in finding one on the lots so I ordered it. A BIG red 2002 Ford F-150 ! I originally wanted the V-6 but I could only order with 4.6 and manual tranny. Lucky for me V-6 doesn't come in that model and 4X4. It would have been WAY underpowered . Not sure if the X2 S/C longbeds could be had with the V-6 . Anyway, F-150 S/C longbeds are a bit "tough" to find.
Whimsey
Old 11-17-2005, 05:26 PM
FordTrucksKickGM FordTrucksKickGM is offline
FordTrucksKickGM is starting off with a positive reputation.
Long beds didn't sell as well as the short beds but they are out there. The only S/c's with a V6 were 2wd. Also a side note. you couldn't get a truck with a 5.4 and manual tranny unless it was in a Super Duty. If you want a S/C with a manual tranny your only option is a 4.6.
Old 11-17-2005, 07:41 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
My next door neighbor has a 2002 SuperCab with an 8ft bed. It has the 5.4L/auto.
Old 11-30-2005, 09:49 AM
KDOGDAMAN KDOGDAMAN is offline
KDOGDAMAN is starting off with a positive reputation.
I own, and have seen many in the Virginia Beach area, a 1994 F150 5.0 automatic 4x4 supercab 8'bed. The F250 in this body style is more common though.
Old 11-30-2005, 05:11 PM
Shampboys 4's Avatar
Shampboys 4 Shampboys 4 is offline
Shampboys 4 is starting off with a positive reputation.
We have many here in the Daytona Beach FL. area.
Old 11-30-2005, 08:21 PM
GammaDriver's Avatar
GammaDriver GammaDriver is offline
GammaDriver is starting off with a positive reputation.
We, too, have some down here. I didn't really see them until I was shopping for one. Then I started seeing them - mostly, if not all, 2WD models around South Florida. My 1999 Ext. cab long bed 4x4 came from PA originally. It was a contractor's truck there, and did it's share of heavy, heavy work. Parts of it are worn out, and I did replace the bedliner due to heavy wear. The 4.6 still runs well (EGR ports probably need cleaned out though), and the Mazda tranny is, well, a Mazda tranny. I like stick shifts, but I wish Ford had not continued using M5OD's.
Was it a rare option? Well, not really - maybe just in your part of the country they are rare. They certainly are ugly though. I would rather own a 1996 ext. cab long bed, but those are pretty worn out I reckon. I'll try to post some pictures of mine soon.
F-250 Made With These Options??? nrowles 1973 - 1979 F-100 & Larger F-Series Trucks 21 03-14-2014 04:53 AM
What's an extended cab 4wd F250 worth? yewdall 1973 - 1979 F-100 & Larger F-Series Trucks 11 07-13-2012 01:38 AM
1979 F250 extended cab short bed question Reds Rod Shop 1973 - 1979 F-100 & Larger F-Series Trucks 1 01-15-2012 11:49 AM
Tire blow out and body damage to Bed, Replacement Panels ?? 6 foot bed Sturmgewehr 1994.5 - 1997 7.3L Power Stroke Diesel 7 08-09-2011 12:15 PM
2010 F150 Truck Caps White mheston 2009 - 2014 F150 1 03-09-2010 05:28 PM
Tags
2004, 97, bed, beed, bones, cab, cb, ext, extended, f150, f250, feet, foot, ford, ft, illinois, option
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
