Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
  #1 (permalink)
Old 11-16-2005, 06:38 PM
bigsid bigsid is offline
Garage is empty, add now
bigsid is starting off with a positive reputation.
Exclamation 88 bronco 11 rough idle
I have 1988 ford bronco 11-2.9 engine. Tuned last year. only put around 500 miles on it. Only drive 5 miles to work when i drive it. Mostly used for hunting. recently notice after car warms up when I come to a stop car will idle rough very slow and most times will cut off. Local mechanic suggested that fuel injectors may be fouled and put some high price cleaner in gas. I filled tank sunday and have driven about 75 miles and still have noticed no difference. mechanic also says 88 bronco11 does not have an egr valve. Is this correct if not where is it?
  #2 (permalink)
Old 11-16-2005, 07:08 PM
IB Tim's Avatar
IB Tim IB Tim is offline
Site Administrator
1989 Swift DB4
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
  #3 (permalink)
Old 11-16-2005, 07:57 PM
frankenbroncoII frankenbroncoII is offline
frankenbroncoII is starting off with a positive reputation.
if it does has an egr valve it would be bolted to the upper plenum just below the throttle body, however if it doesnt have it it will have a plate there with 2 bolts in it.
  #4 (permalink)
Old 11-16-2005, 08:43 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Since you did a tune up try checking the codes and testing the fuel pressure.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
Tags
11, 1988, 1989, 88, bronco, bronco11, ford, hunts, idle, idles, ii, ll, low, rough, running
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
