92 Ranger w/2.3: poor start & no idle
Old 11-16-2005, 02:11 PM
d77telle's Avatar
d77telle
d77telle is offline
My fuel injected 92 Ranger (200,000 miles) always started and ran well...until a month ago. I need to apply gas to start it these days and it will not idle until it's warmed up. Fuel pressure regulator is good, any ideas? Thanks!
Old 11-16-2005, 02:55 PM
66 Beast's Avatar
66 Beast
66 Beast is offline
Sounds like a sensor problem, any check engine lights? If the eec does not go into closed loop, you will not get the "choke " effect for cold starts
Old 11-16-2005, 04:25 PM
Beast12's Avatar
Beast12
Beast12 is offline
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to 4 Cylinder Engine forum.
See ya on the boards!
-Matt
Old 11-18-2005, 04:42 PM
uuranium's Avatar
uuranium
uuranium is offline
check the idle air control. if that goes out then the car won't harly want to run. its located up on the throttle body and you will need to calibrate the new one.
Old 12-01-2005, 11:51 AM
DavidB's Avatar
DavidB
DavidB is offline
I agree that it is most likely the idle air control valve. The best way to be sure is to "pull the codes". I recently had a similar problem with my 87 2.3. When I did the KOEO test it indicated a code 63. Emissions and diagnostics manual indicated a test to run if you get a code 63. Do test by shorting the TP and Ref Voltage connections at the TPS connector on engine side. Then run KOEO test again and see if you get a code 53. I did get a code 53. Manual indicated that positive on code 53 means bad TPS. Replace. I got one at Autozone ($42.00) and installed it. I then got a code 11 (No problems indicated) and the car cranks easy and runs great. No more idle problems cold or hot. Amazing!!
Clean your IAC and if that doesn't help, take it to Autozone for a free check of the engine codes.
Old 01-06-2006, 09:08 AM
d77telle's Avatar
d77telle
d77telle is offline
92 Ranger w/2.3: Poor starts & no idle
Thanks gents, I appreciate your comments. I have a little bit of work to do now that I have some direction in which to turn. Cheers!
VR666
13
06-16-2015 11:14 AM
bigdaddy coolbird
10-25-2014 10:17 AM
79aldean
05-21-2014 04:21 PM
Frank1950
N. California Chapter
05-10-2008 11:38 PM
Quick Reply: 92 Ranger w/2.3: poor start & no idle
