E150 LFC/DTC Code issue
Old 03-23-2012, 10:23 AM
kidtroopa's Avatar
kidtroopa
kidtroopa is offline
3rd Gear
Question E150 LFC/DTC Code issue
Hello all. I just picked up a used '04 E150 that has the airbag light turned on in the dash. The flashing light indicates a LFC 12. However, when I connect my scan tool it gives me a DTC B1342. Has anyone seen this combination before? In looking at other posts I haven't found these two together. They indicate two separate issues.
I've disconnected the battery per instructions in another post but that didn't clear either of the codes. Any and all guidance would be greatly appreciated.
Chuck
Old 03-23-2012, 09:25 PM
Speicher's Avatar
Speicher
Speicher is offline
The service manual shows DTC B1342 and LFC 12 to be the same. Fault Description [RCM Faulted], action to take [Replace RCM]. Restraint
Control Module.
Old 03-23-2012, 09:34 PM
kidtroopa's Avatar
kidtroopa
3rd Gear
Thanks Speicher. I thought LFC 12 dealt with a Low Battery Voltage or something. Where can one download a copy of the service manual for a '04 E150?
Old 03-23-2012, 10:16 PM
Speicher's Avatar
Speicher
Speicher is offline
Try All Data, I've seen their wiring diagrams and they appear to be the exact repleca of OEM manuals. They charge for the use, however they say you can print as well. Others posts say you can register with Auto Zone and view their manuals.
Old 03-24-2012, 12:44 PM
kidtroopa's Avatar
kidtroopa
3rd Gear
Thanks again.
elishaman
1999 to 2016 Super Duty
11-23-2018 09:51 AM
glemons42
1997 - 2003 F150
03-22-2014 11:56 AM
geno001
1997-2006 Expedition & Navigator
10-16-2010 08:24 PM
woolie74
Electrical Systems/Wiring
03-10-2006 07:05 AM
E150
Computer Chips & Tuners
11-05-2004 08:56 AM
Quick Reply: E150 LFC/DTC Code issue
