1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Starting Problem?
Old 11-15-2005, 10:19 PM
CSSuperDuty's Avatar
CSSuperDuty
CSSuperDuty is offline
Question ? Help Starting Problem?
Hello, Guys I am new to the site is AWWWWWESOME You guys are a really good group,I hope to be a long lasting member, Also I just got my newer(FIRST) PowerStroke 2001 Crew CAb 4x4 Anyway Sorry When I start well as I am starting the SD I have to pull up on the gear shifter to start it.
Old 11-16-2005, 12:50 AM
FortyFords's Avatar
FortyFords
FortyFords is offline
Chk on your transmission a switch called a DTR Its a safety switch to make sure you are in neutral or park before starting they can go bad or get out of adjustment.
Crawl under the truck driverside you will see it.maybe its loose if someone had the tranny out it may have come loose.
Rich
Old 11-16-2005, 08:34 AM
CSSuperDuty
Smile cool
Thanx fortyfords i will look after work today.
Shanejet
08-11-2012 03:08 PM
WMDPSD
07-24-2011 06:55 PM
ironarmscott
1997-2006 Expedition & Navigator
01-20-2011 04:29 PM
sammydiesel
13
12-10-2009 04:42 PM
mikeyswood
16
07-13-2006 09:02 PM
Quick Reply: Starting Problem?
