Just added a Vormax Remote mount gauge kit
Old 12-17-2005, 05:44 PM
leskwvo's Avatar
leskwvo
leskwvo is offline
The part number is VFG80R and is available from any Parker distributor. It is very nice to be able to see the vacuum gauge while driving. Before I could only check while stopped and at idle.
The first thing I saw was that at idle the gauge was in the green. Then I jumped on it and the RPM's reach up around 3,000, the gauge went way into the red. Changed the filter and it stayed solid in the green at any RPM range. Up until now I would have had no idea since I was only ever seeing it at idle.
Erick Panger
http://www.leskwvo.com
2005 F250 PSD
Plant Drive Two tank WVO system.
Hotstk, Vormax, A1000 and Vegtherm
Old 12-18-2005, 10:51 AM
cookie88's Avatar
cookie88
cookie88 is offline
Awesome....thanks.
I've never run WVO, but I've had a Vormax in front of the pump for several years.
Are you a Parker distributer? And if not, know where I might find one?
Old 12-18-2005, 11:59 AM
leskwvo's Avatar
leskwvo
leskwvo is offline
Once you go WVO you never go back.
No not a parker distributor. But any parker distributor can order that part #. www. parker.com for nearest distributor.
Erick Panger
2005 F250 PSD
9228.bobcat
09-12-2015 08:37 PM
mongo75
Bio-diesel, Propane & Alternative Diesel Engine Fuels
06-16-2007 09:41 PM
mongo75
19
03-17-2007 09:53 PM
bio-d
12-02-2006 10:39 PM
Quick Reply: Just added a Vormax Remote mount gauge kit
