Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
  #1 (permalink)
Old 11-15-2005, 06:42 PM
jgreen jgreen is offline
Garage is empty, add now
jgreen is starting off with a positive reputation.
87 2.9 strength
hey guys, i just bought an 87 bronco II 4x4 w/ a 2.9L v-6 and have read it only has about 150 hp/torque. i only plan on running 32's on it (got a big ford for big tires ) and was wondering if there is anything bolt on you can do to pump these little motors up? new here so treat me nice. this is gonna be my daily driver so i am not gonn put a 302 in it. well not right now anyways. thanks in advance. btw, what kind of rear end is that in there? where can i get a locker or posi for it?
  #2 (permalink)
Old 11-15-2005, 06:50 PM
oh yeah, i forgot, i have a set of 31's that i am going to put on it as soon as i start driving it, will i need any lift. not worried about a little rub right now, but do want to be able to turn. mostly gonna be my dd, so a 2" body lift maybe?
jt
  #3 (permalink)
Old 11-15-2005, 06:56 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
well the 2.9 is maxed out in stock form so pushing it will make it worse.
  #4 (permalink)
Old 11-15-2005, 07:38 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
You can do a free flowing exhaust, cold air intake, headers, port/polish the intake, free floating rockers...might give you a few more.
I bet you have a 7.5 rear, are you sure it not a posi. Check the door sticker, two numbers is open, letter & number is posi. If your going with that big of a tire you may want to get lower gears since the larger diameter tire will change your final drive ratio.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
  #5 (permalink)
Old 11-15-2005, 08:33 PM
97Centurion's Avatar
97Centurion 97Centurion is offline
Rub my Belly
97Centurion is gaining momentum as a positive member of FTE.
Ken mentioned most everything. Gears would help alot with those tires. I'm running 35's and leave it in 4W-lo all the time. I only wheel with it, no on road use but I would kill for lower gears. Also a 4.0 conversion would make an excellent daily driver.
__________________
2000 f150 (4.2 needed)
1997 f150 4X4
1989 f350 4X4
1988 Bronco II (Mall Krawler)
  #6 (permalink)
Old 11-16-2005, 11:05 AM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
I expect you'll get more bang for your buck getting lower gears in the differentials. There just doesn't seem to be much (cheap) that can be bolted on to the 2.9 to make a lot more torque/hp. If you must play with the engine, the 4.0 OHV is reportedly almost a drop in affair (same motor mounts, same transmission lineup).
Typically, it is said a BII needs a couple inches of lift to fit 31's, though there are a few who claim to fit them just fine with no lift. My '87 is running 235's and only rubs on the sway bar (if the sway bar is installed). I have put the 31's from my Explorer on my BII, and they were drivable (on the street), but they did rub quite a bit. You'll probably have to experiment with yours to see how they'll do.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #7 (permalink)
Old 11-19-2005, 07:11 PM
well, i checked my axle code today and it does have the posi. i've got a leaky valve cover gasket on the driver side, and that needs to be addressed first, so i wont be lifting it yet. the front is 1.5" lower than the rear, correct? so i can put a spacer under/over the coil spring to get that extra 1.5" and that will clear my 31s wont it? well, i have an f150 4x4 with a 8.8 rear and d44 front that is about to get one ton axles, i could throw those under my bII couldn't I? give it a little more strength and a wider track, not to mention drop it to 3.55 without regearing. and the 8.8 has a factory posi too. ideas, ideas, where will i find the time!!
  #8 (permalink)
Old 02-28-2012, 11:10 PM
Orygunw Orygunw is offline
Orygunw is starting off with a positive reputation.
I have had plenty of bronco 2's if I where you I would put 2" spacers in front.
No on the F-150 axles if you want it to bolt up.
Ford explorers on the other hand have an 8.8 rear and a Dana 35 front pumpkin with Dana 44 everything from the axles out. If you have a good junk yard find one that's a limited edition so you can have 4 wheel disc brakes. All you will need to change is the auto hubs to manual. That requires everything on the outer axle from the rotor to the hub. The rear end will need SPRING OVER plates for the right height. Also grab an explorer transfer case and drivelines so you can get rid of the internal slip front d.line.
Besides under parts. 4.0 does rock. Heck spend $500 on craigslist and get a domed explorer cause you'll Need the wiring computer and dash. Anythings possible, just ask yourself how much you love your B2...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
