Bedliner - Ford Truck Enthusiasts Forums
Bedliner
Old 11-15-2005, 05:22 PM
VoteKinky06 VoteKinky06 is offline
VoteKinky06 is starting off with a positive reputation.
Bedliner
Looking into getting a spray-in, does anybody have any advice or suggestions?
Old 11-16-2005, 10:59 AM
duc_grrl's Avatar
duc_grrl duc_grrl is offline
duc_grrl is starting off with a positive reputation.
I absolutely love my Line-X. I did a lot of research before deciding on it (including searching FTE, there's lots of info here) and no-one had a bad thing to say about it. My truck had a drop in liner and with a former 5th wheel & propane conversion (both removed) it had 84 holes of various sizes in the box, which the Line-X covers up beautifully. I use my truck for lots of hauling and the Line-X stands up good to gravel, shovel work, etc.
Old 11-16-2005, 11:04 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old 11-17-2005, 10:02 AM
TruckDaddy TruckDaddy is offline
TruckDaddy is starting off with a positive reputation.
I'm a LINE-X dealer. Let me know if you have any questions.
Where in Texas are you located?
Old 11-17-2005, 11:10 AM
JS2003 JS2003 is offline
JS2003 is starting off with a positive reputation.
I've got a PermaTech and it's very nice. It's more of the rubbery type of liner, similar to Rhino.
Old 11-20-2005, 09:04 PM
opie71's Avatar
opie71 opie71 is offline
opie71 is starting off with a positive reputation.
Line X is great. Just check out the 04-06 F150 area....A guy had a battery tip over and acid went all over the place....The bedliner isnt damaged...but the concrete was alittle shiney after it was all said and done
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 12:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 01:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 09:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 10:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
