78 1/2 F150 Ranger XLT 4x4 400 B/B
Old 11-10-2005, 11:53 AM
Cowboy34's Avatar
Cowboy34
Cowboy34 is offline
Question 78 1/2 F150 Ranger XLT 4x4 400 B/B
i am running 35's w/4.11 gears and i moved to Ohio from Tn and it took me three full tanks of gas on a one way trip.. Is there any thing i can do to be able to get better gas mileage????
Old 11-10-2005, 09:20 PM
danlee's Avatar
danlee
danlee is offline
A tune up, new filters etc.
Check the thermostat. If the motor is running too cold, it will use more fuel.
Replace the timing chain with an aftermarket set, and install the chain 'straight up'.
Rebuild it with 9.0:1 Compression Ratio.
Old 11-16-2005, 03:02 PM
fordraceboy's Avatar
fordraceboy
fordraceboy is offline
what did that equal in mpg's?
Old 11-16-2005, 05:36 PM
fordraceboy
i'm gonna go with a big ouch on the mpg's!!! with those tires you're equivlant to 3.73 gears, pretty good for highway cruising... danlee's gotter nailed for increases that are cheap and easy- tune-up and filters... headers and good flowing exhaust helps FE motors alot..
Elliot Ness
04-25-2014 03:58 PM
wrb36usa
10-24-2013 02:00 PM
Will Brown
1983 - 2012 Ranger & B-Series
05-31-2012 01:04 PM
VaSheriff
10-22-2008 02:32 PM
xtra1es
11-22-2002 06:30 PM
Quick Reply: 78 1/2 F150 Ranger XLT 4x4 400 B/B
