leaf spring to coil spring conversion
I have a 96 F-250 powerstroke and would like to convert the existing leaf springs to coil springs. Any idea if this is possible thru a conversion kit or replacing the axles with newer axles. My old springs are worn out and I would like to get a smoother ride. I live on a large rocky ranch and the truck can be brutal driving around the ranch. Help will be appreciated.
dwd
dwd
yes it can be done. you would have to swap in something like a 4-link suspension. do a search for it. probably in an offroad forum or offroad 4x4 like petersons four wheel & off road. or somethin like it . its not all that bad of a swap if you know how to weld and do a little math and fabrication work.
You can swap in a lot of components from an F150 to make it happen, such as radius arms, springs, spring towers, etc. but it will still require a fair amount of fabrication. You'll need to get the radius arm mounts on that axle or perhaps you could use a front axle out of an F150. I'm not sure though, on that year if there's a strength difference between the axles for 1/2 and 3/4 ton so you could be weakening your front end by making such a swap.
sofob0909
04-03-2011 06:44 PM
dyingtolive
12-04-2010 08:49 PM
