Is it the brake light or ABS light? If it is the brake light, the switch probably just got out of adjustment. You can readjust it very easily. It is attached the the brake pedal. If it is your ABS light, It would probably be the sensors not reading correctly at eh disks. Did you replace the disks when you changed the pads?
