Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-14-2005, 08:13 AM
ksvtwin ksvtwin is offline
ksvtwin is starting off with a positive reputation.
transfer case motor problems
I have a '93 ranger 4 x 4 . it is very low mileage and the 4 wheel drive has not been used much at all. the electric motor that turns the transfer case on is giving me fits. this has been going on since i owned the truck for the last year. when you push the dash button, you can hear the computer box clicking behind the jump seat but the motor won't engage 4 wheel drive. if i take the electric motor off, clean it and reinstall it....it will then engage for about 3 times. then if i wait a few days, it won't work again. the motor is always spotless inside and the brushes look fine. the armature looks clean too and i always polish it a little also. so what can be causing this? anyone else had a similar experience? do i need a new motor?? but how can that be, it's hardly been used?? thanks, Kent
  #2 (permalink)
Old 11-14-2005, 04:18 PM
gearheadz80 gearheadz80 is offline
gearheadz80 is starting off with a positive reputation.
Try going to a salvage yard yard and get a different motor and see if that helps, so that you are not buying a "new" motor that you might not really need
__________________
If its not broke Drive it till it is.....
  #3 (permalink)
Old 11-14-2005, 04:24 PM
ColonyPark ColonyPark is offline
ColonyPark is starting off with a positive reputation.
It seems to me that my dad had a problem with a solenoid on his Bronco II. It's worth double checking that the voltage is getting to the motor when you experience this failure.
Having said that, motors do go bad just as you describe. I have known people who have fought with window motors with the same symptoms you have, only to finally replace them to fix the problem.
__________________
1997 Ranger XLT SuperCab 2.3 5 Speed
1998 Explorer Eddie Bauer 4.0 OHC
2003 E-150 Club Wagon 5.4
  #4 (permalink)
Old 11-14-2005, 08:06 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE. RangerPilot has a very good reputation on FTE. RangerPilot has a very good reputation on FTE. RangerPilot has a very good reputation on FTE.
Yeah see if it's getting enough voltage.
And gearheadz has a good idea, pick one up from the boneyard before giving (and I mean giving) Ford an ungodly amount of money for a new one.
  #5 (permalink)
Old 11-15-2005, 08:15 AM
Sounds like good advice. i know what you mean, i've fought power window problems before too...only to replace the motor and then it works fine. But what blow my mind is the fact that this truck was purchased new in my family. The person that owned it always went to florida every winter and i know for a fact that the 4 wheel drive hadn't been used a dozen times before i got the truck last year. then i used it about 20 times last winter. but the electric motor is spotless inside and the brushes look like new. that is what i just can't understand. if it were an old used motor, i wouldn't even hesitate about getting a different one. but i'll take the advice and get one from a salvage yard. i'll be the one from the salvage yard will have had a lot more usage than the one on my truck. strange problem huh??
  #6 (permalink)
Old 11-15-2005, 08:36 AM
Waves Waves is offline
Waves is starting off with a positive reputation.
My old 93' had one go out when it was about 4 years old with under 60k miles on it...but I used it regularly, I stress the term used, not abused. Point is, sometimes they do just go out, as I recall back when mine did it was very expensive....the salvage yard route is not a bad idea to save a little $$$$$
__________________
2001 Edge 4x
3.0/Auto
8" Wheels
33x12.50 BFG Mud TA's
4.88 Gears and Locker in Rear
Rancho RS-5000's
Flomaster
K&N FIPK
Bama Programmer
I wish using common sense was more common.
  #7 (permalink)
Old 11-15-2005, 08:47 AM
Thank you! I am going to check to make sure it is gettting full voltage when the button is pushed and if it is, i'll get one from a salvage yard. I'll let you know how it turns out. Thanks, Kent
  #8 (permalink)
Old 11-23-2005, 11:41 AM
fixed it!
I fixed it! this is important because i know this must happen often. There was a post on the internet somewhere that told how to rebuild the motor. I can't remember the link but here is the solution:
It is almost always a small plastic bushing in side the gear part of the motor!!! many many good motors are thrown away or replaced at a high cost because of this.
attached to the electric motor is the worm gear box and a position sensor. take the motor off the transfer case, mark the position of the cover plate which covers the sensor. this is VERY important to mark this. take the sensor out, then take out the nylon gear. on the other side of the gear there is a round screw head with a plastic bushing around it. my plastic bushing was actually gone ! some are still there but have a flat spot on them. if they are gone or have a flat spot, the gear will travel out of position which then confuses the computer and the motor won't work!! presto.
so you can cut a fuel line hose or in my case i stacked a couple of vacuum caps on the screw....then trimmed them to length. put it all back together and it works perfectly every time.
I'll bet many rangers suffer from this problem. it is not due to usage, it is caused as much by age as anything. Thanks, Kent
  #9 (permalink)
Old 11-23-2005, 12:12 PM
Thanks for letting us know how it worked. I'll have to keep this in mind if I ever have problems with mine...
__________________
  #10 (permalink)
Old 11-24-2005, 02:38 PM
jolvi jolvi is offline
jolvi is starting off with a positive reputation.
Had same problem on 93 Explorer, had motor replaced by a person where I live. Said same thing as you did will fix it usually but sometimes not he tried, sure would have liked it better if that fix would have worked, but $250 for motor and labor not so bad.
This place that I take it to is big time into 4X4 and says the system is pretty reliable and all has to be correct for it to work
  #11 (permalink)
Old 11-24-2005, 02:44 PM
Might PM Ken00 and see if he'll add a link to the tech thread, since this definetly could solve some problems in the future.
  #12 (permalink)
Old 11-24-2005, 06:47 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE. Ken00 is gaining momentum as a positive member of FTE.
I'll add it the next time I revise it.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
  #13 (permalink)
Old 11-24-2005, 07:11 PM
Thank you very much Ken. I love that tech thread. People say something is wrong and the first thing that comes to mind is, is it in that tech thread?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
