failed nox emission testing - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-13-2005, 07:12 PM
92ranger lady 92ranger lady is offline
92ranger lady is starting off with a positive reputation.
Hey ...does anyone know why my 92 Ranger would fail the low speed emission testing in the Nox (ppm) with a reading of 2794?? the hi speed reading passed @1116?? Just last June 2004 my truck failed and I had the catylitic converter replaced and asstd. other fuel cleaning stuff for around $500.00!! I hardly drive this truck only once a week for a couple of hours!! HELP???
Old 11-13-2005, 07:17 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
For a start, welcome to FTE
Oh, and I moved your thread
Old 11-13-2005, 07:29 PM
Quote:
Hey...thanks for the welcome
Old 11-13-2005, 07:30 PM
[QUOTE=BigF350]For a start, welcome to FTE
Oh, and I moved your thread [/QUOTE
Hey thanks for the welcome...any ideas??]
Old 11-13-2005, 07:32 PM
Ok..hello I finally figured out where to answer ...lol Any ideas ??
Old 11-13-2005, 08:08 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
http://www.txdps.state.tx.us/vi/
Hey, this may not apply to your state, but the point is the same. Find your symptons, you'll get the causes.
In my case of failure, a cat converter matched in both of the categories I failed, so that did fix things for me.
Old 11-13-2005, 09:38 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
If the problem is a high NOx level, then the reason for that is the combustion temperatures are getting too high.
Aside from the obvious things such as a deficient cooling system, an engine that is running lean (that is, too much air and/or not enough fuel) will cause higher combustion chamber temps. Hence, look for air and/or vacuum leaks which could allow air too be drawn into the engine. A new fuel filter couldn't hurt if it's more than a few years old. Also, a dirty Mass Airflow Sensor (MAF) can cause an engine to run lean, you might try cleaning yours:
http://www.ford-trucks.com/forums/sh...hreadid=126093
Old 11-13-2005, 10:00 PM
BinaryWhisper BinaryWhisper is offline
BinaryWhisper is starting off with a positive reputation.
Hi, welcome
Agreed, NOX increases when the combustion chamber temp rises above approx 2500F. It is at it's highest at part throttle with a light load which is exactly what the higher speed test is.
Typically it means that the EGR, or the hose connecting to the EGR is plugged. THat is both the most likely cause and the cheapest to fix. The EGR's primary function is to cool combustion temp's by feeding spent gases back into the chamber.
Advanced timing will raise combustion temps but most vehicles from mid 90's on won't allow you to alter the timing much if at all so it's not usually the cause for them.
Next likely is the Cat convertor but it is very unlikely in your case as you just changed it a bit ago.
good luck
Steve
Old 11-14-2005, 12:35 AM
probedude's Avatar
probedude probedude is offline
probedude is starting off with a positive reputation.
What engine? If 3.0L V6, did the 92' come with EGR? I know my 93' 3.0L V6 Ranger does not - which is quite frustrating since as previously mentioned this is usually the cause of high NOx. Mine has a dist so timing is settable.
I just went through this in So Cal. My NOx was around 1200-1300 at 15MPH and 25MPH dyno. Allowable limit was ~560 and 760.
After doing a good tuneup AND replacing the O2 sensors and cat converter, my NOx readings dropped to 40 and 0 !!!
Did you fully warm up your ranger before taking the test? Just idling before the test doesn't count - idling too long can actually cool the catalytic down.
Old 11-14-2005, 11:01 AM
[QUOTE=probedude]What engine? If 3.0L V6, did the 92' come with EGR? I know my 93' 3.0L V6 Ranger does not - which is quite frustrating since as previously mentioned this is usually the cause of high NOx. Mine has a dist so timing is settable.[/QUOTE
Computer controlled variable timing is one of the ways they were able to do away with the EGR.
If you have no EGR I think you'll find that you can't adjust your timing by tuning the distributor. Don't get me wrong, you can physically do it and the timing will change, but the computer will kick in and change it back. If you turn it far enough to over ride the computers ability to adjust it back then , on most cars, the computer will kick back to the factory programmed saftey defaults and the vehicle will run very rich.
Steve
Old 11-14-2005, 11:29 AM
Rockledge's Avatar
FWIW, there's no EGR on a '92 4.0L either.
Old 11-14-2005, 11:31 AM
probedude's Avatar
Quote:
Originally Posted by BinaryWhisper
If you have no EGR I think you'll find that you can't adjust your timing by tuning the distributor. Don't get me wrong, you can physically do it and the timing will change, but the computer will kick in and change it back. Steve
Computer can't change it back if the only source of the timing signal is from the dist. itself, as it is on my 1993 3.0L V6 ranger.
Computer controlled timing has been around for a long time. I remember I had a early 80's dodge that adjusted the timing on a per cylinder basis. In my Ranger's case I'm guessing the reason for low NOx is also due to low compression, combustion chamber shape, and the dual 3-way catalytic converters (one right after the other).
Here in calif, your base timing has to be within +/- 3 degrees from factory setting. Retarding the timing 2 degrees would still pass the visual/timing test.
Old 11-14-2005, 11:39 AM
Rockledge's Avatar
Another related emissions trick is to pull the SPOUT connector which defaults the ignition to base timing (10* BTDC). This essentially takes the computer out of the equation.
Old 11-26-2005, 01:30 AM
probedude's Avatar
Any update? Did you get your ranger to pass smog?
Old 11-26-2005, 10:17 AM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
Base timing is still adjustable and needs to be checked from time to time. The computer just adds timing to the initial static advance. If the vehicle has no knock sensors then the computer can't retard timing unless its in the lookup tables somewhere. The computer ASSUMES that the base timing has been set to 10 degrees BTDC but the computer has no way of checking the position of the distributor rotor relative to the terminals in the cap. Creative folks have even found ways to adjust the base timing on many vehicles that use distributorless ignitions without using a chip.
Many smaller engines don't use EGR because their tune (spark and fuel) allows operation without it. Very few engines use smog pumps these days for the same reason. Many engines only have a catalytic converter, fuel vapor return and PCV system as their only emission control devices these days. That's in stark contrast to the cars of the 70s and early 80s that had so much pollution control junk on them that they'd hardly run in certain conditions.
If the motor has no EGR valve, there are a couple of reasons why NOx could be high. First off, check the cooling system for proper operation. The thermostat may be sticking closed or isn't fully opening or perhaps the fan clutch isn't operating as it should. Second, it could be the result of a lean mixture. Check O2 sensors and clean the MAF. Also you should always change the oil before going in for an emissions test if its been over 2-3k miles since your last oil change.
Wish me luck guys, I'm about to take my Ranger to get tested right now!!
92 3.0L V6 Ranger failed NOx emissions JohnnyFromOhio 3.0L V6 1 12-29-2005 01:06 PM
1993 Ford F150 NOx emissions too high steve mohler 1987 - 1996 F150 & Larger F-Series Trucks 4 02-10-2005 04:22 PM
92 Aerostar High NOx--failed tonyatram 3.0L V6 9 06-21-2004 01:29 AM
1992 F250 Failed Emissions - high NOX neato5oh 1987 - 1996 F150 & Larger F-Series Trucks 11 08-10-2003 12:30 PM
Help! 96 f150 fails emissions test saltydogs 1987 - 1996 F150 & Larger F-Series Trucks 2 06-21-2003 11:11 PM
Tags
1993, 23, emissions, fail, failed, ford, high, mustang, nox, ppm, ranger, sho, taurus, test, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
