'91 Ford D-150 Nite Brake Problems
My husband just recently purchased a '91 F-150 Nite that needed new brakes/rotars. He is running into some problems removing the old brakes, it seems like he needs some sort of allen key for it, but no sized allen key is working. does anyone know of a trick or if there is a certain tool he would need to purchase before he can remove them? Any help is greatly appreciated!
Brake Removal
I have a 91 F150 2WD. I've done the rotors before as well as the pads. I didn't use an allan key for the rotors (that I remember) and I know I didn't use one for the pads..they just have some sliding retainers that hammer out. They are like a 4" or so rod, but they are diamond shaped (not round). They hammer out with a drift or punch and have a rubber insulator between the two halves.
Its kind of like if you made a rod that looked like this on the end:
<> But there is a rubber insulator between the two ends.
Mike
Mike
dhearn
12-23-2018 06:35 PM
