strut bolt torque value - Ford Truck Enthusiasts Forums
Old 11-12-2005, 03:04 PM
triple8 triple8 is offline
triple8 is starting off with a positive reputation.
I was looking over the instructions to install my Auto Spring 2" leveling kit. I noted that they call out the lower strut bolt torque to be 255 ftlbs. I checked my torque wrench and it only goes to 150 ftlbs.
Whole crap batman is this 255 value correct?
Old 11-13-2005, 07:15 PM
exiled's Avatar
exiled exiled is offline
exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.
sorry brother i cant help you answer your question but i can say that after reading this post and looking at my on torque wrench wich maxes at 150ftlbs also. while i was at sears todaying looking for a 9\16 plug socket i looked at their torque wrenches all of their's also went to 150 ftlbs. but in my 97-02 haynes manual the lower control arm to frame bolts has a 197-241 ftlbs so i guess it can be so might have to get a torque wrench from a parts store maybe advance auto will rent one.
you know i think its crappy all these so called ford enginers in here wont help nobody with anything.
Head Bolt/Stud Tech thread... RacinNdrummin Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 52 12-09-2016 12:24 PM
Important POST spring swap information Hunter,DDS Excursion - King of SUVs 2 02-20-2012 10:25 PM
Front Strut Replacement tooldad 2004 - 2008 F150 6 08-26-2011 07:56 AM
front strut change out rickfar Escape & Escape Hybrid 4 05-28-2011 09:28 PM
Main Studs and Oil Pickup Support? cujo8 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 05-01-2006 07:53 AM
Tags
04, 1997, 2005, 2006, 2008, bolt, f150, ford, front, lower, size, strut, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
