adding trailer brakes?
I added 4 wheel disc brakes to my boat trailer with parts from Champion Trailer; it's an all hydraulic surge activated system, but you can go electric, disc or drum. I got two new axles, 4 hub/discs and calipers, lines, and surge controller for about $1K. They work great and were not difficult to install.
R. -
If that trailer's axle(s) has brake mounting plates, you're in luck; adding brakes will be easy. If not, you'll have to swap out the axle(s). Like Ugly said, Champion should carry everything you need; I put electric brakes on my boat trailer with parts from them (including the axle) and they work great.
Steve
Steve
THE BLUE HEAP
S. California Chapter
06-25-2016 07:02 PM
THE BLUE HEAP
07-24-2014 12:43 PM
