Excursion wiring diagrams - Page 2 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 08-20-2011, 05:16 PM
lawnpro44 lawnpro44 is offline
lawnpro44 is starting off with a positive reputation.
fuses or circuit breakers???
Does anyone have an idea where those circuit breakers go to that are under the hood in those 2 little clusters on the drivers side? My owners manual only has info on the one under the steering wheel. I got some electrical issues and I'd like to know what their function is so i can better work with it. Thats on a 05 Excursion with 6.0 turbo Diesel.
Old 08-29-2011, 04:35 PM
DragOne DragOne is offline
DragOne is starting off with a positive reputation.
I think that one of those under the hood boxes contained the FICM fuse and relays. I need to come up with the diagrams as well since I am having electrical issues with my 05.
added: and the other may be the glow plug module.
Old 08-29-2011, 10:16 PM
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Search e-bay for seller "ultratoolz". You can get a factory service manual on disc that will have every wiring diagram you will ever want for your X.
You can also look for the hard copies. I found one years ago and find it easier to use then the laptop when I'm in the driveway.
Old 08-30-2011, 01:22 PM
jasonodsky's Avatar
jasonodsky jasonodsky is offline
jasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to beholdjasonodsky is a splendid one to behold
Quote:
Are their disks that good, the full manual? The listing looks kinda fishy to me so I was heasitant to invest.
Old 08-30-2011, 02:08 PM
The disc I received is the same one that dealer techs get. They are full manuals for every model of Ford, Lincoln, Mercury for the particular model year you purchase. I think I paid $20 for it.
Old 06-09-2014, 02:28 PM
mblaksley mblaksley is offline
mblaksley is starting off with a positive reputation.
Running lights for trailer towing mirrors 02 excursion
Quote:
Originally Posted by muelheim View Post
Thanks for the replies on wiring diagrams. My 03 Excursion was not wired in the doors for the running light portion of the OEM swing way mirrors I installed. Turn signal is present on the connector but not running lights. I had to run a new wire from the connector to the back of the headlight switch out to the connector behind the door panel. I figured out that the power for the running lights comes directly from the headlight switch and that no relay is involved.
<o></o>
I love the bigger mirrors for towing and now have all the lights working on the mirror housing.<o></o>
<o></o>
I know your post is quite old but you've managed to do what I need to do. I just installed 1A autos 08 style trailer towing mirrors with heat, signal, movement and running lights. Down side is my '02 exc does not support the running lights and I would like to hook them up. I have little electrical experience so any help would be appreciated. I see you wired them into the headlight switch....could you provide a procedure or pictures. I hate to take this to the dealer or an RV shop as you never know what they may do. Any help would be appreciated.
Help with wiring 08 towing mirrors in 03 Ex MoreBoostPlease Excursion - King of SUVs 14 08-29-2015 08:36 AM
power mirror wiring diagram dgulledge 6.0L Power Stroke Diesel 6 03-05-2015 03:36 AM
Another power mirror question sp5937 1999 to 2016 Super Duty 8 05-26-2014 11:46 PM
Side Mirror Pin Diagram Gene Horr Excursion - King of SUVs 4 11-16-2013 10:29 PM
mirror with clearance lights cory5517 1999 - 2003 7.3L Power Stroke Diesel 14 08-09-2013 02:47 PM
Tags
03, 2001, 2005, column, diagram, diagrams, excursion, ford, mirror, panel, power, radio, relay, speaker, steering, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
