Power Poll! - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
View Poll Results: How much power will the new 6.4l have?
325-350hp 20 16.39%
351-375hp 49 40.16%
376-400hp 35 28.69%
400+hp 18 14.75%
Voters: 122. You may not vote on this poll
Power Poll!
Old 11-15-2005, 12:03 PM
duramaximizer duramaximizer is offline
duramaximizer is new and has a neutral reputation at this point.
Quote:
Originally Posted by Kepler4
I believe Ford will at least match the D-max. I hope the torque comes in lower in the RPM range though.
i believe the first part to be true......one can only hope for the second part. as the powerstroke's have been known for higher revs.
Old 11-15-2005, 06:25 PM
Percys Armory's Avatar
Percys Armory Percys Armory is offline
Percys Armory is starting off with a positive reputation.
which plant?
Quote:
Originally Posted by tjbeggs
tlak to my ford guy yesterday who saw and touched the engine while at DANA corp. where they were testing and said around 700 ft lbs torque. couldn't remember HP.
Old 11-15-2005, 08:21 PM
Brian460 Brian460 is offline
Brian460 is starting off with a positive reputation.
Quote:
Originally Posted by PSD 60L Fx4
I'm pretty sure myself and you are the only ones hoping for it
Can I hope too?
Old 11-16-2005, 12:03 AM
NickFordMan's Avatar
NickFordMan NickFordMan is offline
NickFordMan is gaining momentum as a positive member of FTE.
Quote:
I think you mean the 6.0Ls...
Old 11-25-2005, 10:37 AM
PAN's Avatar
PAN PAN is offline
PAN is starting off with a positive reputation.
hey maximizer, isn't the new lbz rated at 360 horse 650 torque?
Old 11-26-2005, 08:15 PM
Frost13's Avatar
Frost13 Frost13 is offline
Frost13 is starting off with a positive reputation.
ford should beat the new LBZ Dmax with 360 HP by at least 15 HP. So, probably at leastt 375 HP and 675 ft. lb. torque. That would be awesome. And nearly problem free too.
Old 12-02-2005, 12:14 AM
mhannink mhannink is offline
mhannink is new and has a neutral reputation at this point.
well i saw its gonna be 370 and 670 the twins will probably bring this in to the 1800-2200 rpm range and it will be pretty flat thro the top end around 3500 4k fueled tho its gonna be a cluster**** under the hood and thro the exhaust w/ all the smog crap they will have on it
Old 12-02-2005, 12:47 AM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
It doesn't look that bad...
http://www.ford-trucks.com/forums/sh...d.php?t=435290
It would be appreciated if you didn't bump the language filters too.
Thankyou for your understanding.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
