Winter beater - Ford Truck Enthusiasts Forums
Illinois Chapter Join Chapter Leader: KOESTNER
Winter beater
Old 11-11-2005, 08:12 PM
JohnT JohnT is offline
JohnT is gaining momentum as a positive member of FTE.
Smile Winter beater
I think I have found a suitable vehicle to use as a winter beater, and I may be buying it tommorow. It's an 89 F150 2wd 302 at 213,000 miles and lots of rust. The truck seems to run good, and everything on it works. It's gray and the body is VERY rusty. It has had a lot of recent mechanical repairs and it seems to be pretty sound mechanically, so I think it will do the job as a beater truck. Also, it has a good CD stereo in it, so that's a plus.
Old 11-12-2005, 11:56 AM
Edberg Edberg is offline
Edberg is starting off with a positive reputation.
Good Deal John Keep the sharp ones out of the snow.
Edberg
Old 11-18-2005, 07:13 AM
Smile
The deal for the 89 F150 fell through because every time I called the guy about coming to get the truck, he had a different excuse for why he couldn't sell it that day. So, I decided to look for a different vehicle and I ended up buying a 68 F250. I got the 68 yesterday. It's a 360 V8, 4 spd, 2wd, manual steering and brakes. The body has a fair amount of rust on it, but it's actually in better condition than the 89 was. The main rust is on the cab (cab corners, lower doors, lower fenders). It seems to run pretty good, so hopefully it'll make a decent winter vehicle.
Old 11-20-2005, 07:17 PM
fairmontman fairmontman is offline
fairmontman is starting off with a positive reputation.
Going heavy duty with the 3/4 ton,sounds like it will be fun to drive with the 4 speed in it.
Old 11-20-2005, 08:34 PM
Fastronald's Avatar
Fastronald Fastronald is offline
Fastronald is starting off with a positive reputation.
Beater
Hi John............I'm sure you'll have many ideas to make that beater a show winner if you care to. Would make a cool basis for a wild 4x4 station wagon or Van too.
Old 11-25-2005, 01:27 PM
Smile
Spent all morning working on the 68 F250 today. I noticed that the lower radiator hose was leaking, so I went ahead and replaced both radiator hoses and backflushed the cooling system. Not a bad job to do, except for the fact that it was like 20 degrees outside today. Hopefully the 68 won't give me anymore problems in the near future! It's not a very enjoyable vehicle to drive because of the manual steering and brakes and it has no radio. But as long as it gets me where I need to go during the winter months, I guess it'll be OK.
JohnT- IL Chapter leader
craigslist deal of the day sean9049 1999 - 2003 7.3L Power Stroke Diesel 14 12-23-2015 04:44 AM
Winter beater mods?? Krisx125 1994.5 - 1997 7.3L Power Stroke Diesel 3 01-04-2011 09:04 AM
New name? 69 and 85 Iowa Chapter 12 01-17-2007 03:55 PM
What year did MAF first appear? subcoolman 1987 - 1996 F150 & Larger F-Series Trucks 11 07-19-2004 11:51 PM
7.3 IDI seems to run cold 79beater Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 12-15-2002 08:08 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
