Need Fuel Line Diagram for 86 F250 w/6.9 Diesel... - Ford Truck Enthusiasts Forums
Old 11-11-2005, 12:53 PM
Katmandu's Avatar
Katmandu Katmandu is offline
Katmandu is starting off with a positive reputation.
Question Need Fuel Line Diagram for 86 F250 w/6.9 Diesel...
I'm looking at buying a 86 F250 w/6.9 Diesel. I have had the chance to see it yet, but the owner says there is a fuel leak that is originating behind the engine towards the top (near the firewall).
He says it's not leaking near the fuel filter or anywhere underneath the truck.
He's describing it has a steady drip.
Where could this leak be coming from ??
Old 11-11-2005, 12:58 PM
Dave Barbieri Dave Barbieri is offline
Dave Barbieri is starting off with a positive reputation.
The location he's describing (firewall) is where the primary fuel filter/water separator is located. It's mounted on the driver's side firewall, above the steering column. If the truck has cruise control, it's directly underneath the servo unit. Mine has been replaced with a Racor unit. Happy, happy, happy.
Old 11-11-2005, 08:43 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
The early trucks had a lot of trouble with the water separator not re seating after pulling the ring to drain it. Many have installed a bolt and clamp in the drain line as it can cause air to be introduced into the fuel system too. If it is not the W/Separator check the line (s) to/from the return line T fitting at the rear drivers side.
Old 11-11-2005, 09:24 PM
Katmandu's Avatar
Question
Quote:
Anyone have a pic of the water separator and the return line T-fitting area ???
Old 11-11-2005, 10:43 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
The return line tee's are pieces on each injector that the rubber fuel line hooks to.
They have two rubber O ring in each cap that get old and start leaking.
Also the rubber fuel lines between each injector gets old and cracks, then it will start leaking.
Ford has an O ring kit of 16 O rings for a few dollars.
You can get some diesel rated fuel line and screw type hose clamps and replace all the lines when you replace the O rings.
Less than a 50 dollar repair to do them all.
I would replace them all at the same time, if you just replace acouple of them, the rest will start leaking the next day after you disturb them.
The return line to the fuel tank comes off the back of the motor near the drivers side rear injector.
That line could be cracked from age where it hooks to the motor.
If the return tees or return lines are leaking, the fuel will run off the back of the valley pan unless it is parked with the front downhill on a fairly steep hill.
The water seperator is on the drivers side in the corner of the engine compartment.
On top of it there is a key ring looking ring you lift to release the water out the bottom.
They do leak air into the fuel system and can leak fuel out the drain valve.
This truck has cruise control on it. The silver bracket is for the cruise, if you do not have cruise the water seperator will be easier to see.
'86/91 F-250 dually 264WSM Vehicles for Sale 0 08-07-2014 08:21 AM
leaky injectors on a 6.9 daw00l Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-09-2009 11:20 PM
Leaking fuel/water separator enprse Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 11-13-2007 11:07 PM
diesel to 351 f2504ever Engine Swaps 5 12-25-2006 07:10 PM
Diesel Kleen in a 6.9 schefner Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 07-29-2005 10:21 AM
Tags
69, 86, 93, diagram, diesel, f250, ford, forum, fuel, idi, injector, leaking, line, schematics, seperator, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
