Oil Pump
Oil Pump
CAREFULLY raise the engine AFTER you have put some pressure on the oil pan with a block of wood and a floor jack.
Remove engine mount bolts and place 2"x4" pieces between the mounts to support the engine.
Drain the oil pan, remove the bolts, pull pan down.
Reach in remove the two oil pump bolts and two pick up tube bolts and slip pump out.
Remove the pan or clean the rail surface and install the gasket.
Assemble in reverse order.
